PDA
View Full Version : My car is Possessed!! Please help!!! IF YOU CAN
Chachi
09-25-2005, 05:48 PM
For some odd reason my car will sometimes stall. :guns: After I restart it, it will run for a second and die.
:chainsaw: Sometimes after I restart the car, it will run fine for a few blocks and then
stall again. :boink: If I jerk the car around with the hydraulics it will allow the car to start up again.
Other times it runs all day with no problems. I know it has nothing
to do with the new Mustang tank conversion, because it did the same thing with the stock tank.
Seems to me that it may be a fuel system problem, but I'm not sure
because I'm not a mechanic, I'm a body man. :poop2:
Blaze86Vic
09-25-2005, 05:58 PM
Yours is CFI right? Sounds like an electrical issue. Most likely a bad ground if it is that. Check the wiring to the injectors and such.
Chachi
09-25-2005, 06:04 PM
Yours is CFI right? Sounds like an electrical issue. Most likely a bad ground if it is that. Check the wiring to the injectors and such. Its (TBI) Throttle body injection. Is that the same as CFI?
Blaze86Vic
09-25-2005, 06:07 PM
Yep
grandpaslincoln
09-25-2005, 06:29 PM
Make sure your TPS (Throttle Position Sensor) is nice and tight too.
mrltd
09-25-2005, 07:27 PM
yep sounds like a loose wire somewhere
Mercmarquis
09-25-2005, 07:48 PM
Mine used to to that too. I took off the CFI and pulled it all apart and cleaned every thing. I cleaned my egr and checked for vacuum leaks. Changed my O2 sensor and got a new air and fuel filter and seafoamed it twice. Now my car runs good and has yet to stall. And Suprisingly the CFI still worked after I ripped it apart.
phayzer5
09-25-2005, 07:49 PM
Check the ecm connector. Should be attachet to the Neg cable right near the battery. Mine acted funky when it was loose
Chachi
09-25-2005, 09:57 PM
thanks guys . :clap: This gives me a direction to start in. I hope it just somthing loose. I'll take a look at it tomarrow if i get a chance. I'll let you guys know what i find out.
Grand Marquis GT
09-25-2005, 10:00 PM
Also, TFI module...
Chachi
09-25-2005, 10:05 PM
what is the TFI and where should i look
Paul_
09-25-2005, 10:09 PM
its on the distributor
phayzer5
09-25-2005, 11:11 PM
the little rectange shaped area at the bast of the distributor with the 6 wire connector
gadget73
09-25-2005, 11:20 PM
You also should check the fuel pump and ECM relays. Thump them with a screwdriver handle while its running to see if the car fucks up.
p71towny
09-25-2005, 11:33 PM
Check your relays and the coil connections. Check the coil connections really well.
NATEHAWK
09-26-2005, 12:06 AM
Ok man you come to the right place for CFI help! Check the connector that plugs into teh TPS and make sure the wires are not lose also even if you have to splice a new connector in do so b/c these connectors seem to just crumble and fall apart. Also check teh connectors at the the two injectors if the tabs are broken replace the connector because the bouce up and down and cause teh car to sput. Also check the main black connector for both injectors in sits right below the CFI housing if its not tight it will bouce around also. Once you check all that and if you are still having problems just hit me up on here or aim and i can walk you thru all teh steps i did to stop my stalling problem with my CFI and everything i checked.
trwp72
09-26-2005, 04:02 AM
the CFI on my '84 is just driving me nuts with it having an intermittent engine miss.... you drive it for a while, and it will start missing when your sitting at a red light.... Then at the next light, it will run fine.... we have changed the plugs, wires, distributor cap and rotor button, found one loose wire where the idiot that had it before me tried to splice the wire on the TPS... with TAPE... and twisted together... if you shook the wire the car would quit! My mechanic was taking the air cleaner off.. and the car quit... he looked over a me and said, "I've never had THAT happen!" So we thought we had it fixed.. as it ran fine after that... until I stopped at the first red light on the way home.... started missing like there was ONE sparkplug wire or plug messing up... but you put it in the scope... everyone is firing fine... So any ides on THAT??? Tom!!!
Chachi
09-26-2005, 07:39 AM
sounds like this is a common problem with CFI boxes. its raining out today so i dont know if i'll get to it today but if i do ill let you know. thanks again.
Grand Marquis GT
09-26-2005, 08:04 AM
Time to drop a 4bbl on that sucka :D
Of course, use a Holley "Low Rider" carb :D
Chachi
09-26-2005, 12:31 PM
I saw those they look pretty bad ass.. I will have to wait till the car is 25 years old. that way i have no problems with all those retarded inspection laws.
Grand Marquis GT
09-26-2005, 12:43 PM
As soon as I saw the low rider carb, I thought of you...
Chachi
09-26-2005, 04:25 PM
Wow thats Amazing !!!
When i first saw it I thought of me too :D
Grand Marquis GT
09-26-2005, 04:34 PM
Somethin about the way people with '84 2dr merks think..
And yes boxmang, that includes you :D
Chachi
09-26-2005, 05:55 PM
Ok, i started it up and started tapin harnesses, and relays but i could not get it to stall. then i unpluged harnesses and pluged them back in still no stalling. but this time when the engine got up to temp it would not maintain a smooth idle, nor would it stay running if i let off the throttle. then i unpluged the harness going to the egr valve and the idle smoothed out but still no stalling... this is driving me nuts
Grand Marquis GT
09-26-2005, 06:00 PM
Did you ever clean your EGR?
Chachi
09-26-2005, 06:02 PM
ya like 4 years ago, but i havent driven it much sence. mabe 1000 miles
Grand Marquis GT
09-26-2005, 06:04 PM
hmm....
try it again.
perhaps it just needs to be driven...
Chachi
09-26-2005, 06:07 PM
i can do that.. but do you think that will fix the stallin followed by a no start
gadget73
09-26-2005, 08:16 PM
Clogged EGR will def make it stall and run like shit. Pull the whole CFI unit and take the spacer plate off, then clean it real good. Just pulling the valve usually isn't enough to keep it running right.
Chachi
09-26-2005, 09:31 PM
but thats just it . the car runs great most of the time. then at random it stalls and wont start untill i shake the car up withy the hydros
85crownHPP
09-26-2005, 10:04 PM
whoah a CFI thread! *joink*
Did you check all the wire harnesses, including the ones for the injectors? Did you open them all up??
A few CFI problems have been due to corrosion in the ignition/alternator wiring harness connector on the drivers inner fender well
My CFI is relatively trouble free :D
Chachi
09-27-2005, 05:58 AM
The first place i looked was the ignition/alternator wiring harness connector on the drivers inner fender well. At one point i had a problem with my alt not turning on. A bad wire in that harness was to blame
Grand Marquis GT
09-27-2005, 07:55 AM
Chachi, we need to get some vids of your hydro's in action! :D
Chachi
09-27-2005, 09:21 AM
if i had the technoligy you would allready have it
Grand Marquis GT
09-27-2005, 11:10 AM
Well, perhaps when you come to SF 06, someone will videotape it :D
Chachi
09-27-2005, 11:40 AM
that would be nice
:D
Chachi
09-27-2005, 11:00 PM
I want to thank everyone for there help i found the problem and most of you were right it was electrical.
today i decided because i could not find the problem i would remove all the butt connectors under the hood and solder all the joints to elimiate posible failures. While i was under the hood i removed some gay blue electrical tape that covered up a lot of wires near the starter Solenoid. Under this i found 2 yellow 12 guage wires conected to one side of a yellow butt connector . this was connected to a 24 guage pink wire
(not factory) which had about 2 inches striped off the end and was wrapped around the batery side of the starter Solenoid. it was corroded all to hell. So i removed it then i cranked the car. It started for a sec then stalled. I tried a few more times and got the same results. Then i restripped the wire and connected it to the battery. the car started up great and ran great. so i'm sure that was my problem.
:clap: :clap: :clap: :clap: :clap: . then after i fixed the problem i took the car for a test drive.. the engine ran great but the spinner on the right rear wheel broke and my wheel fell off!!! :(
so off to the junk yard i went to buy a set of steel factory rims :cuss:
$60 bucks later my wires are removed and black steelies are on.
My car hates me i tell you.
Blaze86Vic
09-27-2005, 11:03 PM
Woah, good to hear about the fix, and sorry about the wheels. You are going to put them back on eventually right?
Chachi
09-27-2005, 11:10 PM
ill need to buy a new spinner hub for the rim to bolt back up.i was thinkin of changin rim sizes any way. the 17" low prophile tired gave me a poor ride. i could feel every crack in the road. will see what happens next spring. mabe 14" deep dish wires with white walls
DarkKnight
04-04-2007, 07:17 PM
BUMPS! demn good Info! :-P
