explorer throttle body setup
    What modifying needs to be done to hook a panther throttle/cruise/tv cable to an explorer tb? something akin to swapping the linkage over with the lopo/ho tbs?
    exactly the same process. Fit the lopo lever to the Explorer body exactly like you'd do for an HO throttle body.
      that lever ain't ever comming off your stang modded TB, haha.
        yeah if you have an HO throttle body thats been modded, leave it be and get another lopo one as a donor for the lever. Grinding the weld off will be a pain in the ass.
          Nope didn't plan on it
