Rear axle
    Rear axle
    Hello there everyone!!!
    I'm going to change the oil and gasket of my differential. Due to a minor leak any way I know my car a 95 town car doesn't have a drain plug, but I do know on how to change the oil but where do I put the new oil in???
    On the other side I seen a plug in the axle I think it was a star or hex key
    I want to make sure that's the refill plug before I pull things apart.
    there should be a bolt high on the driver side of the differential housing on the drive shaft side. That is the fill hole.
      damn so i suppose i need a star and hex set to remove to to fill the hole
        Nope it should just be 3/8 drive. Just get a 3/8 ratchet with and extension and no socket and the square drive should fit right in.
        '90 LX 5.0 mustang
        Big plans
          Huh??thanks alot I'll give it a try
            yep, square drive. There is actually a specific square head socket that you're supposed to use, but nobody owns one and I've never seen one in person. World+dog uses an extension.
