alright its been a big debate wether or not the comp xe258 cam will fit PTV wise in a LOPO bottom end...I finally got the thing and slammed it in and it does. With 1.6RR's, 10 thou milled off GT40P heads, and standard .041" head gaskets I have .150" PTV clearance on the exhaust valve, and .080 on the intake. This is installed straight up no advance or retard. New GT40P's are on and need to build the rest, will have it running for monday so i'll let ya's know how this cam works.
Comp XE258 cam fits...
hmm......
You have GT40Ps....I wonder....it would probably work with TW heads then....
hmmm....Last edited by hemihotrod402; 11-14-2010, 05:04 PM.Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
Originally posted by zoomie View Posti want to see this thing go down the track, make sure to take vids!!
I kinda want to see a dyno run too.....Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
part number 35-510-8... its the high lift .533 and .544. Got the dual springs put on my heads to for .550 lift.
i'm done work, gunna have some quick dinner, and go out in the garage to finish it up and i'll take a vid of the big startup tonight.
She did 0-60 in 8.7 seconds with stock tranny and 4000RPM shift points with this motor and stock stang cam, so I can't wait to see what this does, and tranny swap will be in january so i can hold it to 5500RPM and no major slipping on shifts or the 3rd shift and bog at 50mph either. Here's the motor at the moment...
[IMG][/IMG]Finally have an on the books porting/custom fab business!
P-U-R-D-Y purdy. I don't know a whole lot about your particular cam. Does it play nice with a stock computer or are you going to have to tune it?Originally posted by gadget73There is nothing more permanent than a temporary fix.
Holy shit.
Now i have a crazy engine build idea.Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
cool. I always liked those valve covers.86 Lincoln Town Car (Galactica).
I hope everything works out for you. You have been having pretty bad luck with the engine build and I hope everything turns out fine this time.~David~
Originally posted by merc91 View Postpart number 35-510-8... its the high lift .533 and .544. Got the dual springs put on my heads to for .550 lift.
[IMG][/IMG]
Originally posted by 86VickyLX View PostI like it alot!!!!!!!!! Where'd you get those valve pans? And do you need a spacer to run them?Originally posted by gadget73There is nothing more permanent than a temporary fix.
if you really want to get technical about it, they're rocker covers but who's counting.
Is it soup yet ?86 Lincoln Town Car (Galactica).
