:( :( :( Transmission???
    just today i feel it shifting really hard into second gear as if the engine continues to accelerate and the it SLAMs into second get had to add a bit of tran fluid but what can i do now???
    Check It Out!!!
    Lincoln Towncar 1984
    www.youtube.com/loudtowncar
    You have an 84 right (ps, could you add that to your sig? makes life easier)? If so, check the TV rod to make sure its still connected. If it comes off the CFI unit, it winds gears way out and slams gears.
      ill check it when i get into a garage tommorw where is that located??? why does it only happen from 1st to 2nd
      ill change mu sinature
      Check It Out!!!
        driver's side of the throttle body. Its the big rod that runs down behind the back of the motor to the transmission. There should be a bushing of some sort in the end where it fits on the peg on the throttle body too.
          Moved to correct forum.
          Thanks
          2000 Grand Marquis LS
          Mercury Owners Group member
            While your at it check to make sure the tv rod has smooth action. You can move the tv rod back and forth on its linkage(car off) and make sure it returns back against the throttle stop. You want that tv rod to stay against the throttle stop when you ease off the gas or you'll get a jerky part throttle shift. If the linkage is sticky, you can spray some carb cleaner, quick start etc on there.
            Isaiah
              Thanks Fordman i wanna keep this car long as i can!!! hopefully gonna crawl under the car tommorw to check it out be looking in the haynes manual but cant find must anybody have a diagram???
              Help me save the comfotable car in the world !!!
              Matt
              Check It Out!!!
                Matt
                You can check the tv rod from under the hood... remove the air cleaner assembly for better access and make sure the tv rod is hooked up. It will be attached to the throttle linkage and attached to the side of the transmission. It is about 3 feet long, cant miss it.
                You want to make sure it's attached before you drive anywhere! Inspect where the rod attaches to the throttle linkage, there will be a bushing... it is either rubber or brass. The brass one is better because it uses a clip so the rod can't come off. If you have a rubber one, it's probably original and should be replaced with a brass one.
                I would put a picture on here for reference but am rather computer ignorant. You can search 'tv rod brass bushing' and come up with some pictures and info on here...
                Isaiah
