I have a 01 MGM and i would like to sport loer it ( 1 1/2" )> I cant find anything any where I am baggin it as soon as i get another ride but would like to lower it now. It saggs to the passenger side now. And after I put sterio equipment in next week it will be worse. if any body knows where i can look I would be very greatful. thx
sport lowering????
Custom made are the only option for the rear. Though I have expiremented with a 2.5" Diameter spring for a coilover application. The ends of the pigtails on the stock spring are 2.5" so the 2.5" coilover spring sits on the cups but I have never been able to try to drive a car with them to see if they would stay in place. The springs I was playing with were only 7" long and that's to short. A 10" spring with a 200 lb./in. Rate should lower a sedan about 3-3.5" from stock.
'90 LX 5.0 mustang
Big plans
This has a 2" drop in the front and 2.5" drop in the rear. I'll ask him what springs he hasin there.
08 Lincoln Navigator L - 233k
03 Mercury Marauder- 63k
Clicky here--> http://www.coilsprings.com/
It looks like you have to request a custom set. But if you want them that bad.....
Good luck mang!
God forbid someone uses the search function!
http://grandmarq.net/vb/showthread.php?t=4073
http://grandmarq.net/vb/showthread.p...wering+springs
The 98-02 use a higher rate than the boxes, but the spring dimensions are the same for 79-02.Builder/Owner of Badass Panther Wagons
Originally posted by 1980c10 View PostCustom made are the only option for the rear. Though I have expiremented with a 2.5" Diameter spring for a coilover application. The ends of the pigtails on the stock spring are 2.5" so the 2.5" coilover spring sits on the cups but I have never been able to try to drive a car with them to see if they would stay in place. The springs I was playing with were only 7" long and that's to short. A 10" spring with a 200 lb./in. Rate should lower a sedan about 3-3.5" from stock.
kinda hard to tell, but you can kind of see how the spring angles forward slightly. this is on my 85, but they use the same suspension.
although that is in comparison to my 97, with a 98+ im not sureLast edited by DuceAnAHalf; 12-17-2010, 11:26 AM.http://secondhandracing.com/Home.aspx
