Shocks
    Shocks
    I think it's getting close to the time to replace the shocks on my 91 Gm. The ride is starting to float more than usual. Any ideas on the best shocks for the big boxes?
    1991 Grey Grand Marquis LS Sedan
    61,000 Miles
    1998 F150 XLT 4X2 Flareside Fire Engine Red
    52,000 Miles
    http://www.cardomain.com/id/hdlogistics
    im going coil overs when i do mine also a watts link with boxed lower control arms and adjustible uppers with rod ends
      coilovers? please do tell.
      I use KYBs on the front (GR-2), and Air shocks on the back, but I think im going to ditch the air shocks now that I have cargo coils, for KYBs..
      Good shocks for performance...but they are pretty firm.
        shocks
        I use Variable assist cargo coils for both front and rear shocks. Makes the ride nice, a little on the stiffer side and they look pretty cool too
        SuperFord Profile
        Support safe sigs
        -sigs should not exceed 600 pixels wide
        -sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
        -Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
        -Total sig size should not exceed 60k
        Remember, only you can prevent sig abuse....
          Summit has a coil -over kit. you have a crossmember that welds between the frame rails
          Speedway Motors has all the componets to do it , with springs up to 750# might go with the bilstines
          Quality Parts for Muscle Car, Hot Rod, Racing & more. Trusted by enthusiasts since 1952 for fast & reliable shipping on affordable parts with expert support.
          (check them out for 5.0 parts i got a set of 4340 forged connecting rods from them for $80 the same ones Ford wants over $300 for
          iI can do all the welding required and we have a very competent machine shop right next to us at work
            sounds like a badass setup!
            we expect pics when done!
              also going to try to use Wilwood Forged Dynalite 4-piston calipers up front it will cost under $400 for the calipers, rotor hats,and rotors. thats if i can modify the 92+spindle to accept the brackets
                Are you doing this on the box, or the 97?
                  a pic of what my shocks look like
                  SuperFord Profile
                  Support safe sigs
                    this will be on my 85 , http://www.crownvic.us/forum/showthread.php?t=8139
                    this is the engine going in it
                      wow, sweet 351!
                      Hopefully mines as pretty
                        I want some 90/10 drag shocks...anyone know which ones fit? :banana:
                        btw, im gonna steal that engine
                        '80 Town Coupé
                          lol you gotta find it first
                            I'm guessing somewhere in pinellas county
                            '80 Town Coupé
                              I like the look of the Gabriel shock. Don't know if they have them in Canada though.
                              61,000 Miles
                              52,000 Miles
