Random Stalling?
    Random Stalling?
    When I'm cruising at low speeds my car will hesitate and stall out even when its warm. I'm thinkin the TPS is going. Whatch all think?
    Could be. Stick a voltmeter on it and check it. Or just replace it, since its not a really expensive item. When was the last time the fuel filter was changed?
      A couple weeks ago I changed all the filters and such.
        Goddamnit its still stalling and my valve covers are leaking now WTF!!!!!! :cuss:
        AND I HAVE NO TIME TO FIX IT!!!!
          Check the PCV valve. If its bad or the screen under it (if you have an 86-91) is clogged it could cause both of these problems. The grommet should also be soft and seal around the PCV valve. You'd also do well to check or replace the vacuum line to the PCV valve just to make sure its not leaking.
            Fixed the valve covers today. I ordered the TPS today, It will be here tomarrow. Ya know what sucks alot tho....$52.00 at Advance. For the tps, valve cover gaskets and sealer!!!!!!
              any luck??? could also be a clogged EGR vlave
                I replaced the tps and it seems to have done it. It still might stall right after I start it, but I guess that because I have an older car. But it hasnt stalled while driving so thats a big positive.
