Well, the wagon is gonna be off the road as of today...
    To get the new motor installed :slug:
    :slug: :rock: :banana: :evil:
    Yay!
    Make sure to take pics
      meh..pics..
      Well, got some done today. Not much. Pulled the rad out, the upper intake, some of the trans/engine bolts, the alt and ps pump.
      Found that the intake manifold is really nasty. The runners all really gummed up and the injector bosses are clogged almost to the point of blocking the injectors. Also found that the one bank of injectors are the newer style and the others are the original. Kinda wierd.
        :evil: :evil: :evil: :evil: :evil:
          nice sounds like what I'm doing to my Towncar 5.0. My lower intake was disgusting, so i bought a new one off ebay for $25 bucks lol
            I coulda sent a perfectly clean lower to you for shipping....I have a bunchj of lowers and HO uppers...
