mustang coolant pipe
    Hey guys, I need the metal coolant pipe that runs along the passengers side lower intake from front to back. It came on Mark IV's, 86 towncars, mustangs, and T-birds.
    I think NY Dave has one
      i should have a few on the shelf
        negative. it moved on to greener pastures.
