Anyone know if there is a version of the 5R55 (ie, 5r55b, 5r55c, and so on) that will bolt on to a 302? TCI has one that does. However, its $5,000 not including the stand alone computer. I was hoping that there was a home brewed way of doing this. Like pulling out of an exploror or something.
5r55
Originally posted by 82LTDQS View PostAnyone know if there is a version of the 5R55 (ie, 5r55b, 5r55c, and so on) that will bolt on to a 302? TCI has one that does. However, its $5,000 not including the stand alone computer. I was hoping that there was a home brewed way of doing this. Like pulling out of an exploror or something.89 townie, mild exhuast up grades, soon to have loud ass stereo....
Yeah, but I like the feel of that 5 speed auto. My mothier in law has a V6 mustang 4.0. Its not that fast, but that 5 speed auto feels great. I think it would feel even better with a bad ass 5.0 hooked to it.Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Chasis: 1982 Ford LTD Country Squire
Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
Big Brake swap and front suspension completed.
T-45 5-speed swap.
03 Mercury Marauder- 63k
If you want a 5 speed, put something like ^ he suggested and do an actual 5 speed manual swap. The funny thing is with those 5 speeds, they don't always use all 5 gears, it depends on the conditions. It could go 1345 and skip 2 since 2 is a close ratio to 1st gear, or something along those lines...
Are the 4.0 Liter 6 cylinders using the windsor bellhousing?Last edited by 86VickyLX; 01-12-2011, 08:22 PM.
Someone probably makes an adapter plate to fit a SBF to a Modular transmission.86 Lincoln Town Car (Galactica).
I just want to do it for the cool factor. It seems that a T45 swap is more complicated.Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Originally posted by 82LTDQS View PostI just want to do it for the cool factor. It seems that a T45 swap is more complicated.
Might be slightly more complex to install. But the 5r55 would require a custom trans controller that costs as much as the trans....if they even make a stand alone controller for it.Builder/Owner of Badass Panther Wagons
Originally posted by 86VickyLX View PostIf you want a 5 speed, put something like ^ he suggested and do an actual 5 speed manual swap. The funny thing is with those 5 speeds, they don't always use all 5 gears, it depends on the conditions. It could go 1345 and skip 2 since 2 is a close ratio to 1st gear, or something along those lines...
Check this out.
http://www.performanceautomatic.com/...nsmission.html
It has the trans or the adapterVehicle: 1965 Pontiac Catalina (fastback 2+2)
For the low, low price of $5400. How do they sleep at night?1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
You could have the gnarliest T56 swap, with all the fixings, all new, for less than that.
And then you'd have 6 speeds.
It'd be nice... if you could buy the adapter and controller for a fair price, and supply the transmission yourself.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
