Audio/sub/amp question
    Hey guys, i am looking at pairing this subwoofer: http://www.sonicelectronix.com/item_...SE-1220SE.html
    with this amp: http://www.sonicelectronix.com/item_...KAC-8104D.html
    The impedance of the woofer is 2 ohms...300 watts rms. 1200 peak
    however the amp is rated at 500 watts rms at 2 ohms.
    I dont intend to turn this thing any where near max (perhaps half input sensitivity and half bass boost of the total its capable of.)
    my question is am i safe doing this?? I like the specs and reviews of both products and cant seem to find another satisfiable amp..
    Thank!
    -Phil
    woops this is totally in the wrong section...my bad, mods can you please move it?
    -Phil
      Generally you want the speaker to be rated for at least as much as the amp is, if not more. You can have more amp than the speaker will deal with, but you have to be careful about pegging the volume out. Smoke can and will come out of a speaker, and it really stinks when that happens. Literally. If you've ever melted down a speaker, it emits a rather unpleasant odor.
      and I'm gonna take a total WAG and figure this is for your box, so off to the box audio area with it. If its not, lets just pretend it is shall we?
        thanks!
        Yeah i know...i don't want to fry anything...i suppose i will keep looking. really liked the woofer though.
        -Phil
          Thank!
          welll i can tell you that the sub is junk, i used to work for ABC wharehouse as an installer and the infinities subs arnt all they are crakced ou to be, same goes for kenwood ampslast one i put in could barley make a set of fosgate P1 subs go thump. they(infinity) do however make bitchen amplifiers
          here might be something a bit better and will hit waaay harder and clean http://www.sonicelectronix.com/item_...-DEV-3500.html amp
          http://www.sonicelectronix.com/item_...VI-2000.4.html sub
            http://www.sonicelectronix.com/item_...-P3L-1X12.html
            this would be an almost perfect match for the amp (keep in mind this system will produce far more decibels than i want for the average day so i will keep it turned down a decent amount)
            it's a bit pricier but from what i know rockford fosgate tends to make good stuff.
            or have a heard wrong?
            -Phil
              Zoomie, those are way more hard core than i want lol.
              not looking for anything more than 600 watts rms 1200 watts peak.
              but thanks for the heads up on the infinity woofer!
              -Phil
                they cost about the same as the ones you were looking at lol however i can find you a deently priced amp and sub combo just give me a few min
                  haha okay. i'd really like to not spend more than 300 bux on this setup...
                  -Phil
                    http://www.sonicelectronix.com/item_...io-db1240.html sub the DB series is awsome if you like clean audio
                    http://www.sonicelectronix.com/item_...-HFi1000D.html this amp will do what you ask of it just feed it 4 ga wire both power and ground, it also gives you room to expand if you decide to go with a alpine type R (which i reccomend ) or something.
                      they look good. i really dont have time to mess around with box sizes or making my own any more though. so i really need the sub to be in a predesigned amp...
                      what did you think of the rockford sub?
                      -Phil
                        overpriced for what you get in my opinion , unless you get a an oldschool amp or spend an ungodly amount of money on it the new fosgate stuff sucketh.
                        also fo you want i can build you a custom box mang will cost you price of the material, and shipping
                          build your own sub box. it will save you a lot of money. take a look at the pics in my profile if you need some ideas. having a big amp behind your sub is better than having an underpowered one. the amp will tend to distort at higher volumes if its on the smaller side. more power lets you tune your subs to a lower freq. it allows you to "tune" the system to your liking better. just keep an eye on how your sub handles the power. stay with a monoblock amp. they just work better on subs. for "boom" get a ported box, for tight controlled sound get a sealed box. one ten inch in a sealed box will add just enough to make a factory system sound good. a single twelve sounds better, but bigger tends to be sloppier. you really do get what you pay for. it all depends on what you want this system to do. look at your local pawn and loan stores too. many cheap set ups can be had at these fine establishments.
                          What happened here?
