remote car starters - edumecate me
    I don't know the first thing about these damn things. What would it take to put one in my '88? What is involved in an installation? What parts are needed? Any info is appreciated.
    Every thing you need to know is right here in my head.
    The install is not a hard one on an 88 but it is time consuming.
    if you never done it before. provided there it no factory theft system
    Which there shouldn't because I don't think they were available in 1988
    on our cars. Mostly all the connections will be done under the dash at the
    ignition harness. But not all of them other connections will depend on
    what remote start system you purchase and what features it has and what features you want
      Did you install one on your Merc Chachi? I would also like to get that.
        nate has one too
          Originally posted by lincolnmania
          nate has one too
          I sure do and i love it.. But soon i will be goin carb and i wont have it anymore. Unless Chaci know how to make it owrk on a carb car...
          The Best
            Yeah setup a solenoid to pump your gas for ya
              You could install a cold start injector like old EFI systems had. Basicly they fire a shot of gas in the manifold while cranking so the motor starts.
                i dont think ill ever install one in any car, the 100dollar racer had one, and one day i used it, put the key in moved the car, closed the door and locked the keys in while it was runnin so had to take the BFScrewDriver to the lock
                  How is that the fault of the remote start?
                    Will a remote starter work on a CFI? I know they like to have the pedal pushed before starting when cold.
                    2000 Grand Marquis LS
                    Mercury Owners Group member
                      I have a CFI and it works..
                      The Best
                        Id like to do this too one day. Ill also have a carb. Gotta fix the power locks and stuff first though. My buddy had his installed for about 100 bux at a shop.
                        1989 Grand Marquis LS
                          It’s recommended to not install them on carbureted vehicles but if it will start without touching the gas then a remote starter will work. I have also heard stories from other installers about installing actuators onto the throttle to give it one pump of gas before cranking. I don't have one on my merc, but i have one on my exploder and my wifes cavy. And i've done thousands of others.
                          some r/s systems have a feature called ignition controlled door locks. many people have locked there keys in there car because they don't know how this feature works. this faeture if equiped can be disabled or just do not connect the keyless entry option
                            Even in teh winter?, coolness..
                              Yeap.. Some times it might not start but that every now and then. I have a guy who will be installin a actuator for me like Chaci said to give it one pump of gas before it starts.
                              The Best
