97 P71 Parts?
    97 P71 Parts?
    I am harvesting some parts off of this car. Other than driveshaft and tailhousing what is unique about a P71 in 97? The speedo is gone. I am snagging the rear brake backing plates for a disc conversion on my 91.
    might be worth checking the rear end ratio.
      It is 3.27 which is the standard P71 ratio in 97 from what I have found. I believe it has a worn out trac lok. I will know more when I pull the axles to get at the backing plate. I will inspect the diff. The tag lists 3.27 but the code suggests a trac lok. I have not looked up the tag ID code. As soon as the cover comes off I will know for certain.
      What years use this dash?
        I know that at least 95-97 Aero-body Vics use the same dash which looks pretty similar if not identical to Whale-body dashes judging by this set of pictures of a 97 dash, but I'm not sure if the 92-94 Aeros had the same dash as the 95-97s since that was a big redesign.
        2002 Crown Victoria LX - 124K miles
