'96 T/C headlight problem
    My uncle wants me to fix his 96 town car. The problem is the headlights arnt working. The daytime running lights work, flash-to-pass works, marker lights work, tail lights work. But no headlights or high beams. I put a new headlight switch in and checked fuses, but still the same... Any ideas?
    1980 Lincoln Continental Mark VI Signature Series
    351 4 bbl, AOD, 3.08 open
    duel exhaust with cherry bombs
    isent there some kind of headlight module on them aero TCs?
      I know there is a daytime running light modue,,, But the day time running lights work... not sure about an actual headlight module.
        maybe the DRL module is fried too?
          but they are working fine so I can't see that being fried,,
            but the DRLs work with the regular head lights since, they opperate on the highbeam with lower voltage. do the DRLs go out when you switch the headlights on?
              no they stay the same
                They should go out, and switch to regular lights.
                  ok so maybie the module is fried? They also stay on when the e brake is on, and i think they are supposed to go out then to.
                    yea, when you apply the parking brake, they should go out, so you can just use the parking lights. so, my money is going towards the DRL module. DRLs are gay anyways lol
                      DRL's FTL.
                      1988 MGM GS - Preferred Equipment Package 172A; InstaClear
                      1994 MGM GS Montigua
                      2002 Mustang GT Coupe
                        I heard they're illegal in Germany.
                        You can bypass that module if you don't want to replace it.
                          how do you bypass it? just unhook it?
                            No. You'd have to put some wires together from the DRL harness. But it can be done.
                              Hi Grand_Marquis_LSS
                              The DRLs receive an input from the lo beams could be thats why they are not going out when you switch the headlights on.
                              Assuming the fuses (and circuit breaker) are okay (you said you checked them) with the headlights switched on check there is power on the grey wire from the LCM )Lighting Control Module) to the MFS (Multi-Function Switch), I would check it at the LCM first located above and to the right of the drivers feet, if you have power check it at the MFS, if you do not have power you need to check the main light switch outputs to the LCM, let me know how you get on.
                              Regards
                              Dereck
                              President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
