I'm curious about rebuild kits to use in conjunction with some gofast parts when I eventually do something with my 302. Thought I would post it in here because it'll be the basis for a non-stock motor
Do you folks usually buy rebuild kits from places like Summit? Or do you piece them together yourselves (either for cost effectiveness or part quality or something else?)
The price tag on some of them on Summit is quite tempting when the time comes
http://www.summitracing.com/parts/FEM-EMKP260A-000/
The prices go up from there as the kits include more stuff.
Would you buy a rebuild kit or just buy all of the parts yourself?
Pistons Included Yes
Piston Material Cast aluminum
Piston Style Flat top, with no valve reliefs
Piston Rings Included Yes
Piston Ring Facing Material Cast iron
Piston and Ring Oversize (in) Stock
Rod Bearings Included Yes
Rod Bearing Undersize (in) Stock
Main Bearings Included Yes
Main Bearing Undersize (in) Stock
Cam Bearings Included Yes
Gaskets Included Yes
Oil Pump Included Yes
Oil Pump Volume Standard-volume
Oil Pump Pressure Standard-pressure
Oil Pump Driveshaft Included No
Freeze Plugs Included Yes
Camshaft Included No
Lifters Included No
Timing Chain and Gears Included No
Assembly Lubricant Included No
Plastigage Included No
Quantity Sold as a kit.
Lifters Included No
