mustang oil pan in 302 colony park '85?
    hi to all. i want to make my 302 colony park little bit faster and powerful . as for it i bought some performance parts and start a rebuilding of my engine. also i want to change my oil pan to the racing pan (such as moroso, kevko, canton etc.) but the most of them are made for stangs and other fox platform cars. does it fits to my panther? and what types of sump locations can i use? thank you.
    '85 Colony Park LS
    fox body mustang oil pans can interchange with the panther variety afaik. same dual sump arrangement.
      5.0 panthers use the same dual sump oil pan as the fox 5.0 mustangs
        good news. thank you. i think that pans are same, but some performance sites confused me when i read that performance fox pan didn't fit to panther car.
        '85 Colony Park LS
          None of the performance sites know anything about non-Mustangs.
            yea, the kinda people who only know of mustangs and F seies trucks. the only fords out there lol
              like mentioned above, it fits. I have a Canton 7qt. pan in my car.
                good engine on the photo above! as i know it's in your crown vic? and what about long headers? how did it fits? and what about power steering?
                '85 Colony Park LS
                  Long tubes don't fit on panthers. Power steering is stock. And will bolt up to the new engine. Use all of your stock accessories on your build, and you'll have no problem with fitment issues.
                    they are actually mid-length headers, and i had to modify them to fit. as far as i know they are the only set that will fit a panther, others have tried to make a set and i dont think anyone has came through yet. the power steering is not a problem, but the shifter linkage is.
                      but i didn't want to use only stock parts i want to make a performance engine because stock car drives like granny's wheelchair
                      '85 Colony Park LS
                        as i see there are many pans with front sump on ebay, but very few pans with dual sumps or rear sump. why? and as i know our cars needs rear or dual sumps pans?
                        '85 Colony Park LS
                          Its not the pump that makes the steering the way it is. Its the steering gear itself. A later model one will help with the "granny's wheelchair" feeling.
                            as i see your canton oil pan is more deeper than stock. as for it i have a question - which is the lowest point in the bottom of your engine compartment - a new oil pan or not?
                            '85 Colony Park LS
                              the oil pan is in no danger unless your car is really lowered or you insist on jumping it over stuff. im almost certain that the exhaust is lower
