PDA
View Full Version : AOD valve body upgrades
taylorendicott
02-15-2011, 04:40 PM
Has anyone found a good reilabe valve body kit for an AOD? Or is there and easy todo upgrade that can be done with the parts you already have like the 4R70W's JMOD.
zoomie
02-16-2011, 12:38 AM
lentec
taylorendicott
02-16-2011, 09:00 AM
I saw Lentec on the web before by demised it. I was thinking of using a TransGo kit, I've herd good things about their products and their cheap, plus I like doing things myself. However tell me more about this Lentec, is it something you've used?
Ghorneck
02-16-2011, 09:07 AM
Not sure if he is still building them, but Gregg Evans at Factory Tech built the valve body's I have in both my '89 F150 and the '94 E150. He builds torque monster transmissions, mostly for diesel applications as in turbo P/U's. He must be getting old now, but you could try Googling his name or Factory Tech.
1980c10
02-16-2011, 04:48 PM
Im gonna use a silverfoxx valve body when I put mine back together. Check out www.clickclickracing.com to read on his stuff
zoomie
02-16-2011, 09:24 PM
i personally dont have one ,my trans has nice firm shift as is, but ill probably get one eventually. i know other people who have used them before. the silverfoxx ones are said to be very good as well
here are few links you can check out, mind you everyone has thier own preference for parts. might want to check out some of the stuff on foureyed forums and other sites to see who has luck with what.
http://www.lentechautomatics.com/aodhome.html
http://www.silverfoxtrans.com/silverfoxtrans.com/VB_AOD.html
http://www.tciauto.com/products/ford/ford_aod.asp
http://www.ford-aod.com/
