15" CV Police Wheel Covers
    I'm looking for 15" OEM Crown Vic Police-style (although some civilian models were also equipped with them) wheel covers in good condition.
    Thanks.
    the dog dish or the full size hubcaps?
      I was originally thinking of the full size, but I might be interested in the dog dish, depending on condition and price. Thanks.
        A nice alternative (and probably cheaper) is to get Explorer/P71 centercaps and lugnuts. They actually look pretty good on 15" wheels. I reinstall mine when running my 15" winter wheels to keep the nuts and hubs from getting all salted up and gross.
          1987cp -- that's a good idea. I'm going to look into that. Thanks.
            Sure thing!
            I'd check eBay or car-part.com, or possibly a local 'yard. I'd imagine those caps would be plentiful right now, provided not all of the ClunkerBombed Explorers have been crushed already .... oh, and plastic doesn't dent.
              my guess is the nuts are a different size than stock?
              ive been looking into this but i didnt want to order the caps unless i knew they fit
              1985 Mercury Grand Marquis ls-302 CFI
              Carb swap planned .
              c90 heads
              475 lift cam
              Weind stealth intake(looking for reasonable air gap or manifold for 2bblsidedraft)
              Built aod(want c6 tryin to fin vac mod model)
              331 stroker kit
              Work in progress
                what vehicle should i tell my parts guy i need the nuts for to get the right ones?
                Carb swap planned .
                c90 heads
                475 lift cam
                331 stroker kit
                Work in progress
                  "Parts guy"? The counter guy at AutoZone will look at you really weird and direct you to the "Rally" brand chrome garbage. Do you have a reliable salvage yard in your area? If so, that might be your best bet, unless maybe they're still available from your Ford dealer.
                  To my knowledge, these caps (and matching shouldered lugnuts) came on '98-'02(ish?) P71s, and some Explorers (dunno the year), though I've also seen some on Rangers.
                  Not sure what you mean by "different size", as they've got to be 1/2-20 or you have problems. I have one set of shouldered nuts with 13/16" hex, and another with 3/4" hex. No idea why.
                    I have the full wheel covers, also a set of tall caps and lug nuts.
