colony park vs. country squire
    how much is the same (exterior) between these two models? based on pix, looks like the front header panel is different, but how 'bout the rest from the fenders back?
    same year span? ('79-'91 is it?)
    thanks.
    header panels and bumpers changed from 1987-1988 along with the squire hood .... squire hood uses same hood as grand marquis and colony park used from 1979-1991... tail lights are different between them also
    Addicted to 86-87 Panthers
      the colony park tail lights wrap around to the side for the marker and are sunk into the side of the 1/4 panel.........the country squire tail lights are flush with the back of the 1/4 panels and they have a separate side marker lamp.
      working on yucatechs wagon we found the side marker sockets with no bulbs while checking and tidying wiring, i guess they used the same wiring harness too.
          i belive the hoods are only same on 88-91 boxes. the tailgates, doors, front fenders and trim are the same. and the lighting harness is shared between the two models. i bet you would find the bild sockests for the B pillar coach lamps on a vic too.
            The trim for the woodgrain is slightly different too. It should interchange, but the CS stuff is woodgrain printed with a plastic wrapper on it. the CP stuff is chromed with a woodgrain insert. it actually weathers significantly better than the CS stuff does. Looks better too I think.
              yea, a decent amount of sun exposure will cause the squire trim to peel and whatnot. pretty nasty. and i agree, the colony park trim does look better IMO.
                79-91 grand marquis has the same hood.......88-91 vics use the grand marquis hood
                  ^^what i meant
                    so is the rear quarter the same (CP vs. CS) other than the taillight cutout (wrap vs. non-wrap)?
                    and if i read this correctly, the header panel would be the same on a pre-'87 CS?
                    does the CS fender have the cutout for the turn signal cornering lamp like the CP?
                    those are the three main pieces i'll need.
                      the rear quarters are same other than the tail light area. and as far as the fenders with cornering lamps, both mercss and fordss came with them but, were an option for boxes. so its a luck of the draw kinda deal.
                        if you look close at my wagon (factory non woodgrain) you can see the ford tail light knockouts
                          I've never noticed that before! You can even see them on mine (where the woodgrain has stretched and split)
                            funny you dont see punch out marks on a Country Squire... scroll to post 50 where there are shots closer of the rear...
                            http://www.grandmarq.net/vb/showthre...t=flying+brick
                              I have never noticed that on mine!!! I will have to look at it closer tommorow and I will let you all know!!!!!!!
                              '88' MGM wagon (mine and my sons toy)
                              "60" chrysler New Yorker (my project)
                              "78" Chevy 1 Ton P/U (yard horse)
                              "01" Ford Explorer (wifes DD)
                              "93" Chevy Suburban (my DD)
