View Full Version : 5 speed
Grand Marquis GT
04-05-2011, 06:56 PM
Yes, I been thinking about this.
I know some dude over on CVN did a real nice writeup, so I gave it a gander. Doesn't look too hard, either.
Perhaps I should do this later on, once I get my other projects out of the way? Then I'll really have a new Grand Marquis GT :D
Crownvicman289
04-05-2011, 07:20 PM
No balls if you don't. You referring to the Canadian guy who, IIRC, has also since done a 5.4 swap?
GoodSamaritan
04-06-2011, 05:32 AM
I don't know about an 09, but it's not too bad on a 95.
Ususally the worst bit of a 5 speed swap, is getting the clutch pedal in, and set up properly.
johnunit
04-06-2011, 03:00 PM
having seen that 5.4 5speed swap in person, go for it. That thing is super cool.
pantera77
04-06-2011, 03:47 PM
Ya it is, I even raced him! (and lost obviously)
Pesty351
04-06-2011, 06:15 PM
Do it!!!!
P72Ford
04-06-2011, 08:07 PM
Personally...
I'd leave the car alone. Its a reliable daily driver, and there is alot to be said for that. I know we're all into modifying cars and such here, but I have really grown to appreciate a daily driver that is simply 'unfooled around with'.
If the transmission took a dump or something, I could maybe see it; but not for an otherwise perfectly functioning driver.
gadget73
04-06-2011, 08:14 PM
Good point. There is a reason my daily go-to-work vehicle is absolutely dead stock. It starts and goes every morning.
Lincolnmania
04-06-2011, 08:18 PM
yea i would leave it alone till the trans shits the bed
slymer
04-06-2011, 08:54 PM
my DD is not bone stock because of crap rotting off of it. First the air box snorkel... then the crossover pipe for the air injection to the cats... then the muffler detonated...
etc etc...
but it is still bone stock as far as the engine proper is concerned. Though if 87CrownVic doesn't buy the HO intake stuff off me... I may spend the time one weekend to load up mine with it. re-pinning the computer harness for the injectors and all since I don't have an HO cam (or the desire to do that much work).
86VickyLX
04-06-2011, 09:25 PM
etc etc...
Sorry about off topic buy why would you repin the computer harness? Lol. You'd only do that if you had an HO cam and didn't get an HO computer.
slymer
04-06-2011, 10:14 PM
I have the HO intake, TB, bored egr spacer, computer and injectors but not the HO cam. So I'd have to make the HO computer compatible with the lopo firing order.
Lincolnmania
04-06-2011, 10:30 PM
i got a couple exploder cams
Crownvicman289
04-07-2011, 01:21 AM
And now the adaptive learning strategy applies its readings to the wrong banks, that's why I left mine alone. My current DD, the CV, is extensively modified. Of course my truck which is the DD stays stockish for the reasons mentioned above, but DD'ing a modded car is no problem if you have a backup for the downtime and you do the work properly. There's a 4L80E swap and a Whipple waiting to go on the truck in the future, it's being optimized for its only reason for existing: towing.
slymer
04-07-2011, 02:33 PM
seriously?
bah. ok... in that case... If 87Crown Vic doesn't buy the stuff... just sell it. It's really not worth the hassle for me to pull the engine unless something else is replacing it.
86VickyLX
04-07-2011, 02:37 PM
What would you need to pull the engine for? Lol. Can swap Cam in car.
slymer
04-07-2011, 03:03 PM
pull engine... or pull AC... pull the engine, don't need more parts... pull AC, gotta get dryer/accumulator, expansion valve, refrigerant and oil. Plus I don't really have the ability to work on anything that's going to take up more than one day with that car. I can swap the upper intake easy enough... and injectors aren't that bad either... repinning the harness would be a little tedious, but probably won't be bad... but replacing a cam would take minumum a few days since there's soooo much crap that has to be removed/replaced to even get to it. Even if I opt to remove the AC/RAD to get at it... it would still take too much time. I'd have to take a week off from work to allow enough troubleshooting time as well. I really am debating just selling the parts I have and waiting until I can build a complete engine for a total swap.
mrltd
04-07-2011, 05:07 PM
I did the head and cam swap in my 87 in around 4-5 hours, in the down time between two jobs....With hand tools. Granted my car didn't have smog pump or AC
Lincolnmania
04-07-2011, 05:17 PM
you dont have to discharge the ac, you lay a blanket on the right fender and lay the condensor and compressor on the fender
86VickyLX
04-07-2011, 05:26 PM
Yeah, I pulled the front end off of my car after I smashed it into a tree. The Condensor was bent to shit, but it still held the AC charge. There was enough hose to allow me to hang the condensor over the side of the car. I didn't replace the condensor until I was ready to put the new front end on.
And all you'd really need is an accumulator if it was apart before and a recharge if you actually took the system apart.
slymer
04-07-2011, 06:09 PM
I'd still replace the expansion valve if I took it apart since that's where crap usually collects.
good to know it can be done that way. my main issue is getting the damn fan on and off. takes me 2-3 hours just doing that. Those fan bolts suck. Took me 7 hours just to change the water pump on my car. I would guess that with the radiator/condensor/grill out of the way it would be way easier to get stuff off. The rest of my issue with it is that I would rather have forged internals for my eventual TT project. Best way to do that is just build it and throw it in via a full swap. I also wish they made steel core rubber gaskets for water pumps (if they do... let me know... I'll save the info for the serious build... if I ever get to it). I'd rather put some form of rubber/permadry gasket on every surface I can instead of paper/cork. I really do wanna go super big under the hood. Dunno what I wanna do about a trans at the time though. more daydreaming though :D
pantera77
04-07-2011, 07:08 PM
Wat. The fan takes like 5 minutes to take off. And if all your doing is throwing an HO upper on, then why are you even touching the computer?
johnunit
04-07-2011, 07:36 PM
he was thinking of doing everything (including injectors and TB) for an HO swap except for the cam.
slymer
04-07-2011, 07:43 PM
and no... the fan does not take just 5 minutes. with a box end wrench (the only tool I have that fits in there) and those f'n fan bolts that are an inch too long... it takes me about 15 minutes per bolt for the first 2. the second 2 come out easier though. The whole time, my back is generally unhappy with the position too, so I have to take frequent brakes to keep my back from giving out on me. This may be the main issue. I love to wrench on the cars... but my back doesn't... and my back wins.
86VickyLX
04-07-2011, 07:57 PM
I leave the belt on until the bolts are broken.
And the blades moving separate of the pump shaft makes it better!
slymer
04-07-2011, 08:01 PM
so do I. My bolts are just bugger tight for the last half inch.
86VickyLX
04-07-2011, 08:08 PM
Did you undo the belt when you were ready to take it off?
P72Ford
04-07-2011, 08:41 PM
Oh...
For a second there I thought this was a thread about Tom deciding to do a 5 speed swap or not.
86VickyLX
04-07-2011, 08:57 PM
Oh...
You're right.
DO IT! I say this because if you get around to doing it, that means that the truck is done! And I really wanna see that F100 done!
Grand Marquis GT
04-09-2011, 09:49 PM
Irrelevant to the thread posts are irrelevant.
Get out!
And eventually I want to do a 5 speed swap. I don't see it happening right now of course, but it will make the car so much more fun :D
Crownvicman289
04-12-2011, 12:09 AM
Just buy the parts. Once they're sitting there you won't be able to resist. Believe me when I say the car feels a lot lighter, and even with 3.08's it seems there's always a good gear to be in. I can't wait for the 3.73's and trak-lok now.
