hey everybody so i just found the site and its awsome! i have got a 85 lincoln town car that im doin body off and totaly redoin and updating and about a month ago while doin my workin on my new frame for the car i thought that a 4.6 would b cool in an box and diffrent so i went and got a 95 crown vic 2 days later for parts haha and went to town at the moment i have the 4.6 in the car and getting things mocked up im just woundering if anybody has done it b4?
4.6swap?anybod else done it in box
Thanks, i will have sum pics up by tomarow and sum of the car i have a fully reinforced from for the car im almost done with its plated on all 4 sides with 1/4' thick steel fully molded and smothed and gunna b painted with a pearl and gold leafing done and the whole bottem of the car is being sandblasted and painted with a candyrootbeer brown, with sum patterns and gold leafing!
i did the opposite, i put a 302 ho into a 4.6 car
yes it runs well and it beat having to find a 91-92 4.6 engine
the late model radiator is too high in the box, or just the trans lines don't line up properly? Do you have the trans lines on the correct side of the motor mount bracket? i've done that before.86 Lincoln Town Car (Galactica).
the 95 rad fit fine but 95 condensor was too tall to fit in the rad suport but my 85 condenser has the older style threaded fitting but i looked at my 88 towncar and it has the same quick disconect style fittings as the 95 a/c system so thats solved and i will able to use the crown vic 4.6 a/c system, for the tranny im just using the factory trans but i would like to do sumthin to beefin it up abit since i have added alot of extra weight to the car, for fuel im using the crown vic tank sending unit and all lines
AOD isn't going to bolt up to a 95 4.62020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
heres the car the drivetrain came outta, 95 crown vic
whats the easiest way to pull the axle, trans mount/crossmember, and motormounts?
motor mocked up on the frame with crown vic brake booster and heaterbox
front clip on with crown vic inner fenderwells
