easy to add cruise control?
    what would i need to add cruise control to Grey October? is it something i can pull off shifty? i know i would need a new wheel at least, but i'm sure there is more i would need
    Save a seal, club a liberal.
    You could get an aftermarket setup. JC Whitney, Summit, any of those would have it I'm sure.
    '95 Ford Bronco XL -
    sigpic :rebel:
      out of curiousity, if the car was optioned without it would the wirining still be there and functional?
      i know i'm getting annoying but what can i say
      i've checked my 1990 evtm, and the shop manual and found nothing
        look and see if you have a little black box near the ECM... thats where my cruise module is.
        If you got that, a trip to the yard will get you the ball, cables, and the wheel!
        If not, dont give up. I think cruise got intergrated into the ECM at some point
          CVN is good for tech occasionally, lol. I learned that the '90-'91 boxes had cruise integrated into the ECM. All I need for the installation is the servo(what does that look like and where is it?)and a wheel with cruise buttons. This will be another project for me to tackle down the line.
          I still want an '04 steering wheel.
            Cruise servo is the funny round doohicky on the driver's side fender. Its located near the brake booster, and should have a vacuum line or so, an electrical connector, and a cable that runs over to the throttle body.
              Where is the vacuum distribution block? Coming off the servo, there is a line going into the cabin, and another line that snakes behind the wiring harness, and I can't find it again.
                Found it, it's in back of the upper intake manifold on the firewall. As soon as I get a hold of a new wheel with cruise buttons, I'm starting this project.
                  Earlier than 90 had integrated cruise......my 89 has it.I think it was 88-89 that it changed. Prolly was a change along with the body...
                    1988 I think came the integrated cruise.
