Hoped it wouldnt happen but it did. My air sus. went out. So im just going to convert them to shock/spring setup. Is there any thread that would greatly help me?? Do I have to drill anything?? or just remove the old stuff and slap in the new things with no hassle?? Any help is greatly appreciated!!!
Rear air suspension
Make sure it's off before you start working on it. Should be a switch in the trunk for the air suspension (in my aero it's on the right, the fuel pump switch is on the left)
No drilling.
You can use this as a guide
http://www.lincolnsonline.com/tech/00132.html
Then just install the coils like you normally would....I dunno what year your car is but that applies to most Panthers. You likely have conventional gas filled shocks already.sigpic
