91 Grand Marquis (5.0L with AOD trans) will only start in neutral and stalls if I put in park reverse or 1. It moves in drive but not taking off in lower gear like it should. i have to drive real slow till it gets up to 35 mph then shifts and goes great, almost like there is no 1st gear, it imeediately stalls when shifted into R or P like the engine comes to an immediate break.In 20 years of working on cars I never seen anything like it. Can anyone help please.
91 Merc Grand Marquis won't start or run in park. Will start in neutral but stalls
That's friggin' bizarre.
I would suspect the neutral safety switch for at least part of your problem.
In what condition is the transmission fluid? Is it a high mileage transmission that has recently been serviced/flushed, by any chance?
What is the condition of the TV cable and its bushing at the throttle body? It's the one that isn't the throttle cable or cruise cable. Check at the transmission end, too.
Can you check it for vacuum leaks?sigpic
+1 bizarre.
sounds like the torque converter may be too tight (I thought they would just let go when going bad, not tighten up though) or the engine has severe vacuum leaks or is running f'n rich (re: no low end power).
I think you have multiple problems. Start with basics. Check codes and vacuum gauge.
