Does anyone know if there are any j/y shafts that fit an aod wagon?
Aluminum driveshaft
Aluminum driveshaft
Tags: None
grab one out of an aero.Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Originally posted by GoodSamaritan View Postgrab one out of an aero.
What years encompass the aero cars?
Thanks
thanks
you can use aero ones but you have to swap the axle flange (or is it the yoke flange?) and use a special U-joint, there is a part number for the u-joint around somewherePete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP View Postyou can use aero ones but you have to swap the axle flange (or is it the yoke flange?) and use a special U-joint, there is a part number for the u-joint around somewhere
Do you mean the pinion flange?
I installed 4.10's not long ago & they are perfect, I sure don't want to disturb that!
Originally posted by mrltd View PostI put a plain old box one in mine
Might be the one on the other end, I can't remember, lolPete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by mitymerc View PostDoes anyone know if there are any j/y shafts that fit an aod wagon?Last edited by Mercracer; 08-18-2011, 11:34 AM.
Originally posted by 85crownHPP View PostNo Im pretty sure you can leave that alone. The driveshaft end that mates to that - you swap the box one onto the aero driveshaft, so you need the funky U-joint to mate the two parts that weren't meant to be together.
