Grand Marquis MONSTER CAR - $2500 (RED LODGE)
    http://montana.craigslist.org/cto/2571822677.html
    GRANDMA MEETS MAYHEM! Plan your next weekend to the mountains in this 1984 Grand Marquis mounted on a great running 76 FORd F150 4 X 4 with a 360 motor and auto transmission. Inspected and titled. This one is too much fun! Even Granny agrees! $2,500 , obo. 406-425-2938 7:00 am to 8:00 pm, seven days a week.
    The simple way to fit a 351 EFI truck intake under the hood.
      heh... 360?
      mild bore of a 351?
        Ford FE series 360 made for trucks from 68-76 don't think there real common
          Marquis Abuse! Looks like shit to me....just my humble opinion.
            What were they smoking??
            '79 Continental Town Car
            '90 Crown Victoria LTD
            '94 Crown Victoria
              apparently I'm smoking some similar stuff... I wanna 4x4 my 88... but with a 408W (or better) and an 8th gen frame (116in. wheel base) and solid axles.
              I wanna be able to smoke the 39" tires :3gears:
                I'm right with you Slymer. I'd love to have something similar.
                  the main thing that makes swaps like these ugly is that the chassis always sticks down below the body. If you could somehow tuck stuff up it would look cool.
                    Pain the frame flat black, or better yet, undercoat it and ignore it.
                    If that were closer I'd be very tempted... Except I was thinking more along the lines of a f600 frame.
                    Axle codes
                    Open/Lock/Ratio #
                    G / H / 2.26
                    B / C / 2.47
                    8 / M / 2.73
                    7 / - / 3.07
                    Y / Z / 3.08
                    4 / D / 3.42
                    F / R / 3.45
                    5 / E / 3.27
                    6 / W / 3.73
                    2 / K / 3.55
                    A / - / 3.63
                    J / - / 3.85
                      take the F150 frame and weld it flush as you can up under the car as close to the axles as possible (assuming the reg cab short bed 116" wheelbase truck frame). Keep enough of the frame intact for the suspension mount points. once that is all on the car... cut the excess frame off and weld those pieces, with necessary brackets, to help stiffen the frame of the car... up flush and neat. Boxing in the frame can also help. The point of setting the car on the frame first before cutting is to make everything straight and true and putting in the main brackets/supports needed first. This will not only give you the needed lift without much help for basic swampers (small 30s), but will keep the geometries the same for the stock F150 bolt on stuff.
                      Another option is to just weld the whole works on and fashion storage boxes to fill in the gaps between the frames to keep messy stuff (road side kits and fluids) out of the trunk.
                      Other truck frames will require cutting first since they are a much longer wheelbase than the 114" panther.
                        I love it
                          Originally posted by gabegt90 View Post
                          I love it
                          What kind of transmission modification do you need to make to move wheels that big?
                            Well since its just a body swap, that means that it likely has the factory transmission, which I assume is a C6, so it should be able to turn 44+ inch tires without any mods as long as the diffs gears are swapped to match the wheels. But the factory AOD in our cars can run at least 31s.... since my Bronco has been on factory 31s for 26 years and 150,000 miles with the stock original 302 and AOD. As long as you change the diff gearing its not much harder on the transmissions.
