BerniniCaCO3
09-04-2011, 08:29 PM
Just to double check; there are NO coolant lines hooked into the upper intake, are there?
I just discovered coolant on the pavement after driving my car this morning. At first panicked, because it was dripping off the back passenger side of the engine, but then I noticed that it's puddled across the entire center of the upper intake, so it can't be a head gasket or even the lower intake gasket to get there.
I'll pull the upper intake tomorrow and see what's what. Might have to pressurize it to pinpoint it.
What are some likely culprits?
I don't think I've got a single hose clamp on the upper intake however, so, if any thing is coolant and not vacuum, that's a very likely culprit to be seeping liberally
I'll also look at that plastic return pipe from the heater core, in case it could be cracked-- does it have such a reputation? I'll check the hose clamps at either end.
If it is leaking, can I replace it with real metal pipe from the hardware store?
I can't remember where the hoses to the EGR coolant run; if under the intake, them too...
