clunking/grinding
    clunking/grinding
    I was driving the TC today and when it hits about 45 it makes that sound, I think it's when it's shifting into 4th gear. When I put the shifter in regular drive so it doesn't have 4th, it doesn't seem to make the sound. It's not as bad as my old Vic when it would just miss 4th completely and never get into that gear, but the sound is concerning at the very least.
    I'm gonna take it to a shop tuesday to have the tranny fluid and filter changed since it needs it, hoping that helps but the problem is probably deeper than that.
    They clunk into overdrive... That's normal operation of the aod...
      AODs are clunky. If the trans mount is shot or if the U joints are sloppy, they clunk worse though.
        yeah... shouldn't be a clunk when it shifts... just a bit of a kick in the ass so to speak (jar the car a bit). If there's an audible clunk of metal... something needs attention. I've got the "A" solenoid and band in my AOD and it kicks like a mule if you ease it into OD at about 47mph... but nothing clunks.
          It clunks. The Mark VII guys have been bitching about them since they were new...
            a properly working aod will clunk into 4th gear under light throttle
              Originally posted by Lincolnmania View Post
              a properly working stock aod will clunk into 4th gear under light throttle
                I think of it as more of a lurch than a clunk. I've never heard the actual shift to call it a clunk. the shift kit I have in my 88 now does make it kick like a mule though... that and the HD parts.
                  It's actually more of a grinding, like when you're trying to shift a manual into a gear and the engine speed isn't quite right, so it grinds. Or like when trying to shift a manual without the clutch at all, sounds like gears grinding. I'm about to take it to have the tranny fluid and filter changed, i'll have them check the pan and fluid for metal deposits to make sure nothing is too bad.
                    .... not good. slush boxes should NEVER sound like that. You're looking at a serious rebuild... probably complete set of gears. You may luck out and it's just the clutches completely roasted and metal on metal... but keep in mind... it may be a serious rebuild.
                      If it needs a rebuild, i'll treat it like my old Vic and not use overdrive at all.
                        that's probably what you'll need to do then. As long as it's JUST od that does it... it's probably the solenoid/band that needs replacing. If that's all... the rebuild may not be that bad depending on the shop. But it will probably run $500 at least.
                          My old stock AOD would do the Clunk/Rhythmic Vibration thing when shifting into OD at 1/4 throttle. With the throttle down any further it wouldn't clunk into OD, and would shift smoothly. My current rebuilt AOD w/ 50K on it is doesn't clunk into overdrive regardless of throttle position, and is smooth as butter all the way through its gears, you can barely even feel it shifting. Which is how I like it to be in a Luxo Ride.
                            grinding may well be U joints. It should definitely not do that.
                              The collection of metal in the trans pan will tell you....
