Will it fit?
    Will it fit?
    I know for a fact that my Mk VII LSC AOD was too long for the '89 CV CS.
    I've got a buddy that has an '86 AOD from a TC, that works & is priced reasonably enough to over look the fact that it is an '86.....
    Will it fit the '87 CV CS?
    Or does it have the long tail like the LSC trans?
    Thanks
    The Town Car AOD has the longer tailshaft as well. I didn't know that the LSC did though.
      Lincolns have Lincoln Transmissions. If I'm not mistaken, they're the same length as truck AODs. If you want to run Lincoln AOD in a Vic, or Marq, you'd either need custom driveshaft, or find a Lincoln Mark VI Two Door. Since that has the same wheel base as vic, but uses Lincoln AOD.
