Hi guys,
I am planning on putting two 12' subs, closed box and an amp in my car (1991 MGM LS). I listen to a lot of electronica (Hardstyle, trance, hardcore. Pretty sure closed is best) and am looking for a powerful bass (around 500-1k watts for each sub) and obviously an amp that can handle this. I thought since I am starting without any of these components, it would be best to buy a package. These are a few packages I'm considering, any suggestions are appreciated.
http://www.sonicelectronix.com/item_...s-Package.html
^^Rms rating of those amps seem to be in line with the subs.
Obviously I'll need to install a capacitor as well, and while I'm at it (just to be safe) I'll put in a 3G alternator. I'm wondering what the best way to wire the system up with the capacitor is. I've been advised to use 0 gauge wire as well. I plan on placing the subs in the lowest area of my trunk (12' sub box wont fit on the shelf) facing towards the rear of the car, is this going to be a good place to install the subs? Also, how should I wire my amp to my subs ohms wise?
Any help or suggestions are appreciated!
~Stealth
~Stealth
