WTB '89+ AOD valve body, A servo, relays, auto-dim amplifier, TV cable
    Hey guys, I'm on the lookout for a known-good 89'+ valve body for the AOD, as well at the "A" overdrive servo that had better clamping force from the supercoupe AOD. Also looking for 89 TV cable and possibly linkage at the trans side.
    Also looking for any relays relating to the auto-dim headlight circuit, including the high to low beam and the sensor amplifier that goes on the rear-view mirror. Thanks.
    Would you want a Supercoupe valve body?
      yea I'm interested! Have to check if it will fit my Lincoln, I'm thinking it will but I'll check Alldata and Mitchell at school today and see.
        I'll check the yards, I recall seeing a few SuperCoupes, not sure what years though.
          harrys has 2-3 super coupes one red one and one white one. i would check those out john.
            I got a valve body now, and a "B" servo, but if you found an "A" servo would still be interested.
              Try www.silverfoxtrans.com
                One of those tranys we were going to trade for the HHP wheels is a 90 ot 91 witgh linkage. Will still trade for them if you come get it.
                  I'll know this week if this valve body fixes my issues or not, I'll let ya'll know how it goes.
                    Installed the used VB, adjusted the shift linkage (which was off), found the 2-3 accumulator had popped it's C-clip and was cocked in the bore :/ Fixed all that and it still slips badly in 1st gear from a stop, and neutrals out in OD.
                      Oh, was that your problem? That's not a valvebody problem!
                        We'll it's a bit more complicated, because the transmission was completely overhauled with new clutches and seals, new OD band, shift kit, and brand new torque converter <500 miles ago. Wouldn't shift out of first after the rebuild so pulled VB and found couple valves stuck, had to ream the bores and install an oversized 1-2 shift valve (i think) and then we got 1-2-3 but OD would slip out... it's a mess right now lol
                          Bleh. Might try posting up at ClickClickRacing, but I'm thinking (and I'm no AOD expert by any means) that your tranny is royally screwed. I think that's the technical term ....
                            To hell with it, I'm swapping in a T5 >
