PDA
View Full Version : crazy idea, 385-series BB
BigMikeIT
11-19-2011, 12:49 PM
Hi,
What would need to be done to put the 429 PI D0OE-B into my 87MGM?
Is it in the realm of possibility?
Is the 8.8 rear enough? Which tranny's would I need?
Thanks.
Grand Marquis GT
11-19-2011, 01:12 PM
Check this out:
http://www.grandmarq.net/vb/showthread.php?44268-My-1989-Lincoln-557-cobra-jet-project-in-progress
It's been done, but it WILL require some werk.
BigMikeIT
11-19-2011, 01:25 PM
Check this out:
I'm the in the beginning research stages.
Hmm. That's the 460? So I guess the 429 PI version may be a bit lighter.
Maybe a 427 cammer. I'm looking for a specific sound, since 302's can be upgraded anyways.
1990LTD
11-19-2011, 02:05 PM
427 cammer = good feckin' luck
BigMikeIT
11-19-2011, 09:03 PM
Aaaaahhhh, 38K-60K...............
Maybe the 429PI is the better wish list block for a biggie.
Forget about the cost of just the engine. Everything else drivetrain would need to be replaced too.
And even if that was done, the cars would be a fish on the road. Oh well.
1987cp
11-19-2011, 09:56 PM
It's an interesting idea that lots of people have thrown around and then decided to just get a junkyard Explorer engine. I'm pretty sure the main hassles would be things like exhaust, motor mounts, and bellhousing compatibilty.
Too bad the linked thread doesn't seem to provide a whole lot in the way of details, since that project looks quite neat even though I spy a carburetor of outdated design ....
What do you mean by "specific sound"?
BigMikeIT
11-20-2011, 01:55 AM
Well, I have these 18" cherrybomb glasspacks, though with the original 3-way cats still on.
When I accel hard (and drain the gas tank with the original injectors), I can only get that cool popping just before the converter stalls forcing the next gear. I want to get a good robust hotrod popping like from that '70 Dodge Coronet in the movie '25th Hour' (see here:
http://youtu.be/gD22Ae3kHLY). Link to movie http://www.25thhoursuperbee.com/25th_hour/ABOUT.html.
I remember a friend of my mine in college having an '87 T-bird with the 302HO engine and these no-name chrome looking glasspacks that made a nice raspy sputtering even when idling. Sorta sounded like Smitties, but more like smitties blowing into a pillow. Very unique sound. He didn't know which type they were, installed from an American Muffler shop. Maybe it was the HO.
Actually, the glasspacks on my car are just as old as the tires I need to replace (10 years, Vogues) and they sound even better.
I often wonder just how loud my current exhaust is, since folks back off when I accel on the highway. The current exhaust on a factory (Canadian) lopo 302 F code engine with stock manifolds. I noted in one of my earlier posts that the car originally had four cats, two small ones near the end of the manifolds, then the existing two 3-ways. Now just the two 3-ways exist. If I could pry open the old cats, gut the ceramic, then MIG them shut.....
What would I need to do to get that "Dodge 440 Magnum 6 Pack Super Bee" sound, and still stay Ford?
Thanks
johnunit
11-20-2011, 02:25 AM
4 barrel carb and more aggressive cam will net you a meaner sound, not to mention actually making the car meaner.
johnunit
11-20-2011, 02:40 AM
Also, shorter glasspacks will sound rawer, and playing with exhaust tip size and shape will make a difference.
My car is about as raw and poppy sounding as a stockish engine gets, and it has cats. Removing cats will make it louder, but generally not change tone/smoothness much. I started my car up with the exhaust hacked after the cats, and it was basically like mildly quiet open headers. There's a quick video of it if you check my reader's ride thread.
Increase compression, swap to a performance carb, and stab in an Ho cam or hotter aftermarket cam, and you'll be much closer to the sound you seek.
1987cp
11-20-2011, 07:08 AM
Interesting. Guess I'm not much help, since I've long since lost interest in being loud. My cars have to be used for family transportation, so I do what I can to keep them smooth and quiet! It's actually surprising how much my views on noise changed once I no longer had a stock 2" exhaust in place - changed from wanting to be heard, period, to wanting not to go deaf!
Actually, several cam-tech threads at SBFtech.com talked about the reality of being able to have a Windsor motor that idles smooth at 600 AND zing to 7000+rpm while making a ton of power. Not the same as the old lumpy-idle type of street cred, though. Their point of view seems to be, build an engine to make good power, and then have a cam guy design a grind to do what you want it to do. For me, I'd want a completely smooth idle, but if you want a lumpy idle, they can of course do that too.
johnunit
11-20-2011, 07:30 AM
Lookin at the specs of some of the cams at sbftech, i'd think they'd idle smoothly in terms of speed and vacuum, but I think the sound would still be meaner than a stock lopo.
marquisman
11-20-2011, 09:12 AM
you cant really get shit out of a lopo 5L. the exploder 5L with either 4bbl or EFI with a more meaty cam, would change it all. i dont regret doing my engine swap. the car sounds mean and people dont expect that badass sound to be commin from a 2door marquis lol
1980c10
11-20-2011, 09:58 AM
A H.O. Sounds completly different than a lopo anyway, in a good way. They sound alot meaner than the lopo, but it is a different firing order, bigger cam, different heads, intake, and pistons lol.
86VickyLX
11-20-2011, 02:14 PM
I have to disagree with you there. I heard no difference between what my Explorer engine sounded like compared to my lopo I pulled from it. Save for the lovely knock the lopo had when it was cold...
If you want a cammy sound with a smooth cam, wire a toggle switch to ground the EGR vacuum regulator. That'll make it sound lopey. Just be sure to turn it off before you drive it or you're gonna look real dumb.
johnunit
11-20-2011, 03:00 PM
I think it's a cam thing. My 351 sounds more like an ho than lopo or explorer. It also has similar duration and more lift than the ho.
marquisman
11-20-2011, 04:52 PM
the HO and LOPO sound different. maybe not if you got stock exhaust.
slymer
11-20-2011, 09:34 PM
lopo - Stock Y pipe with magnaflow muffs (sounds the same with H and duals, just a smidge louder)
http://www.youtube.com/watch?v=44NwpAIFzZk#t=0m15s
93 HO no cats and unknown muffs (this is in my Mark)
http://www.youtube.com/watch?v=I45dTLrlQZg
sounds different to me. The lopo doesn't have as much ... lump? pop? grunt?... whatever you call that lumpy idle stuff... as the HO. It's not a whole lot different, but it is different. And when you stomp it, it's rather different.
and just for grins and compares... 93 4.6L stock with magnaflow cats and muffs.
http://www.youtube.com/watch?v=2bMLUPdo4Lg
I actually like the sound of the 93 the best.
79lincolnlover
11-20-2011, 09:44 PM
Especially with old tires...
Mercracer
11-23-2011, 07:39 PM
There is negligible weight difference between any factory 429 (except for the Boss) and any factory 460. They use the exact same blocks and rods with a different stroke crank. There is little weight differences between the CJ, PI and garden variety heads. Same goes for intakes.
Unless you have $20K for a core engine, forget about a 427 SOHC.
The fact that you don't know this reflects that this is likely just bench racing and not a serious project anytime soon. Do yourself a favor and swap in an Explorer motor with a cam swap.
mrltd
11-23-2011, 09:33 PM
Sploder motor with a cam, xpipe and edelbrock mufflers.
http://www.youtube.com/watch?v=tAqagNybgHA
http://www.youtube.com/watch?v=wNZ0uj5g6H0
http://www.youtube.com/watch?v=QceqdSYFDwQ
slymer
11-23-2011, 10:25 PM
"he wins"
umm... yeah. :lol:
