Steering, suspension sqeeky noises
    Just bought 2000 grand marquis with 26k miles and it seems to be hard to keep her straight while driving it floats around. Is that normal also when it rains and when I move the steering wheel it makes loud sqeeky sounds when it is dry makes the sound very little what could that be
    Low mileage car, likely nothing is actually bad but it is almost 12 years old. Have you checked for any grease fittings on the front end? I suspect there are none, but its worth a look. THe U joint in the steering shaft, roughly underneath the brake booster is known for doing this. I dont know if you can lube it, or if it has to be replaced when it gets stiff.
      Took her to the mechanic and my steering gear
      Box is bad and I need to lube my bushings
        How does the steering gear go bad in 12 years/26k miles?
        Should probably make sure your alignment is at least close. I got my alignment very wrong during a hurried tweaking session last week, and the results were almost dangerous!
          I'd have a hard time believing the steering box is bad. They last at least 5x that mileage in most cases, unless it was used as a security guard car in a parking lot or something unusual like that. I put a box in my car that had roughly 13k on it and it was like brand new. Its probably got 25k on it by now, still plenty tight.
            I'd hit the steering linkage with some grease and see how it goes.
            08 Lincoln Navigator L - 233k
            03 Mercury Marauder- 63k
              Yeah, that's odd. Most cars never even need the steering gear replaced during their lifetime, especially one with under 100k mi. Unless it's a factory defect or something weird happened like a bad power steering pump, or a major loss of fluid and somehow ended up wrecking the steering box. Or a lot of moisture somehow got in.
              I know the steering shaft on the Panthers can be a little problematic sometimes. And unfortunately there isn't much to grease on the steering systems on Panthers either. Most of the steering stuff (tie-rods, pitman arm, idler arm, etc) is non-serviceable (non-greasable) stuff.
              1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
              1985 VW Vanagon 70k~
                Took her to another mechanic and all I need is an alignment and grease up the bushings
                  second opinion FTW!
                    Really? When'd they start doing that?
                    I seem to recall reading a recommendation to install a grease zerk anyway ....
                      Wish that were true. In my garage right now are two different vehicles known to need new steering racks under 100k.
                        I'm not sure, but not a single joint/end on the steering on my car has a grease zerk or a hole for one to be put in... The aftermarket pitman arm I just bought has a zerk though.
                          Well I did say most...
                          What kind of car(s)? It kinda seems like racks go out more often than the recirculating ball.
                          Not only that, no one ever pays attention to the fluid/hydraulic side of the steering system until it's leaking or totally shot. If I had a nickel for every time I heard a car with low power-steering fluid wailing around I'd have a lot of beer money.
                            early 90s. Basically the round cars.
                            Racks fail quicker because they take more abuse. No gear reduction or steering linkage to take road shock. Theres also no lash adjustment to help compensate for worn parts. Once its done, its done.
                              Wow. One more reason not to swap to a rack!
