Have you seen anyone running an Edelbrock Carb intake???
    I am looking at the Edelbrock intake with the electronics to run a carb. I could then install an enrichment tank in the engine compartment with a pump and install a nitrous plate. I think I could get into the 13s that way.
    ive heard that the airgap intake is a nice intake also offenhauser and a parker-web funnel too
      I am talking specific to the 4.6 Mod motors...
        your wanting to run a carb but run the ECM too or are you wanting to use a NOS plate between the manifold and the elbow.
          NPI block, PI heads are the ticket, too.
            Depends on wether the heads are to be ported or not. Ported the NPI heads flow better.
              A few guys on CVN are.
                No elbow. Run a Carb using the Edelbrock electronics for the ignition. I already have an Edelbrock Performer RPM Nitrous Plate system which goes in between the carb and intake. Performer RPM is the name of the system and has nothing to do with what intake you run it on.
                  Running 4V carbs on Mod Motors???
                    Think you need to explane what your up to a little better as a Performer RPM is also an intake manifold. Anyone else a bit confused?
                      Performer RPM is also a pair of cylinder heads.
                      Edelbrock has named its plate nitrous systems Performer, Performer RPM, Performer RPM II and Victor Jr. There is nothing to be confused with as Edelbrock has heads and intakes it uses the same names for. They are just names which suggest levels of performance.
                      In other words, you can (although you certainly don't have to) take a Performer RPM Nitrous plate system and bolt it on top of a Performer RPM intake which is sitting on a pair of Performer RPM heads.
                        No, but that intake with an elbow on it.
                          I am asking about carbs...
                            My first thought is running a AODE or AOD
                              I will keep the PCM in place for the shift maps... and even feed it the engine tach signal, etc.. It will have no idea that there is a carb in place..
