Planning to go distributor less in the near future (with some luck). Need the pump drive/ cam sensor not so much the sensor as it wount be used. Would like to ditch having a distributor which would be usless exceptt o drive the oil pump out of the way. It is used on the last years of the 5.0 in the Eplorers. Would be an easy pic if your pulling an intake and heads from one.
LTB Oil pump drive/cam sensor
