View Full Version : fuel pump eccentric hits cover
84merc951
01-31-2012, 06:10 PM
im helping a buddy put in a 1974 302 into his cv. he bought a new double roller timing set and a 1 piece fuel pump eccentric as the seller didnt inclued those parts. the problem here is that the timing cover is hiting his eccentric. the eccentric is a 0ne piece and the timing cover is also a 1974. what do we do. thanks
84merc951
01-31-2012, 08:10 PM
bump bump
84merc951
01-31-2012, 08:35 PM
i read that we can eaither grind down the eccentric or not use the double roller and just buy a stock oem replacement. whatch think guys
slymer
02-01-2012, 12:15 PM
You can also wire in a low pressure fuel pump as well (though more expensive). Most modders I've seen just grind down stuff till it fits.
1987cp
02-01-2012, 01:55 PM
Funky. Where and how is it hitting?
Is this fuel pump eccentric intended as a stock replacement? Did it end up installed with a spacer under it that it shouldn't have?
Mercracer
02-01-2012, 02:19 PM
This is a common issue. Just get a 2 piece eccentric. There is no reason to Bubba a 1 piece to fit as the 2 piece are plentiful.
.. Most modders I've seen just grind down stuff till it fits.
Most I know use the proper parts.
84merc951
02-01-2012, 02:31 PM
i called ford racing and they said the double roller timing set we bought is for a 2 piece fuel eccentric and that we need to by the set that uses a 1 piece. i guess the thickness of the cam gear is different between the 2. we had a gap of like an 1/8. we knew it was something to do with the timing set because we through his old non-roller stock set on with the 1 piece eccentric and it fit just fine. yea his motor in his 81 cv blew up so he bought a running 74 302 for like 50 bucks off craigslist and all it needed was a new timing set. thanks for the replys
slymer
02-01-2012, 04:15 PM
most I know are kids or rednecks. you can probably infer the rest.
gadget73
02-01-2012, 07:30 PM
So they're Chevy guys?
slymer
02-01-2012, 08:32 PM
and ricers
84merc951
02-01-2012, 08:53 PM
thanks for the help and knowledge. i order a double roller for my buddy that uses a 1 piece eccentric, 37 bucks from summit and your right i red online that this happens alot with smbf swaps with new parts. thanks again 84merc.
1987cp
02-02-2012, 06:31 AM
Huh, if that's the case that'd be why I never had that trouble. My double-roller engine ended up with a 2-piece eccentric, and my 1-piece eccentric ended up installed over a non-double-roller timing set.
P72Ford
02-02-2012, 07:12 AM
I was afraid this would happen when I had the engine apart for my car last year. There are specific timing sets for either a 1 or 2 piece eccentric. One has a raised mounting surface on the cam gear (I believe the two piece), and one does not.
The dowel pins are different lengths for a 1 piece, vs. 2 piece eccentric, as well.
