Vic to mustang.
    Vic to mustang.
    Would my 5.0l from my 89 vic fit in my 95 mustang? can i use the same moutns and junk, or do i need new stuff?
    1989 LTD Crown Victoria LX.
    -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
    4 Door Muscle
    Supermotors
    mounts wouldn't be two much of an issue. they had the 5.0 in the stangs till 94 and 94 was when the new body style came out. so if yours is a 95, should be fairly simple.
    is this a 5spd or an auto 'stang? if its a 5spd, shouldn't be too hard to mate the motor with the tranny.
    the only major prob i can see tho is making the 5.0 play friendly with the computer.
    Save a seal, club a liberal.
      as long as you keep the same induction there shouldnt be a problem
        its a 5 speed.
        4 Door Muscle
        Supermotors
          you are going to need the intakes from the 95 mustang, ho cam, 19lb injectors, mustang fuel rail, mustang engine mounts, water pump etc
          the block will bolt to the t5 yes
            Times
            Whats the 1/4 mile time and 0-60 time for a stock 3.8l v6 5 speed?
            4 Door Muscle
            Supermotors
              many variables
              race conditions
              condition of car being raced
              driver ability
              you could have a 13sec capable car,but if the driver can't launch it right, you're fucked
