I have a 97 marquis and the instrument panel(speedometer gage,temp gage,ect.) Its not lit at all. Pretty sure the bulb/bulbs blew. My question is how many light bulbs would I need to buy more then 2?
Instrument panel light
Slightly off topic but can you get to the bulbs behind the IP on an 1987 GM or do you have to pull the panel to change bulbs?
You have to pull the speedo out to get at the bulbs but its not too bad. I'd think an aero or whale cluster would have at least 8 bulbs.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
try adjusting the knobs on the headlight switch (the one that turns the overhead light on) just in case it's turned all the way down (would make the lights all super dim).
Originally posted by slymer View Posttry adjusting the knobs on the headlight switch (the one that turns the overhead light on) just in case it's turned all the way down (would make the lights all super dim).Last edited by Mlee19841; 02-26-2012, 06:39 PM.
in that case... yeah... probably the bulbs.
So, I dug into my parts bin for some answers. And I got them.
Standard early Aero (and some boxes) have the horizontal speedometer.
Like:
On the backside, look like this :
Pay no attention to some of the parts that are missing. There's a reason it was in the parts bin.
These units have *8* bulbs for illumination.
They are marked ILL
These are the clusters on most 95-04 Panthers, not including the Marauder and digital dashes:
Like:
On the backside, they look like this:
These have *6* bulbs for illumination.
They are also marked as "ILL"
Both clusters use BULB #194.
Yea!!!!!
03 Mercury Marauder- 63k
most of those bulbs are the indicators and warning lights.
