Just bought a 88 Towncar
I would drive it for a bit and see if any bugs surface. If you are going to keep the motor, perform all basic maint.
If you don't know what has been done when, oil, antifreeze, suspension and body lube, wax, silicone, hoses, belts, plugs, wires, cap, rotor, PCV FILTER brake fluid, tranny fluid, check the brake lineings, change wiper blades.
The bigest things I would upgrade first are tires and headlights.
This all assumes the stuff is somewhat old and you do not plan on upgrading any of them in the near future like bigger wheels for instance.Last edited by jaywish; 03-04-2012, 11:04 PM.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Thanks man...what "type" of goodies can be added to the engine with a $$ figure?
...i got $3500 to play withLast edited by Grand1; 03-04-2012, 11:03 PM.
1979 Marquis creamy goodness
then duals, shocks and upgraded sway bars, maybe springs, assuming lincolns don't come with appropriate sway bars.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
sorry im not to mechanically inclined (trying to fix that)
by duals you mean dual exhaust?....what would that do...make my car faster...???
Originally posted by jaywish View Postthen duals, shocks and upgraded sway bars, maybe springs, assuming lincolns don't come with appropriate sway bars.
Dual exhaust would increase the amount of flow in your exhaust, resulting in less restriction, and making more power, and better fuel economy. So yes, make your car go faster
for $3,500 you can have a better motor and exhaust installed. Do not neglect suspension, brakes, tires and lights. I would say do those first, see how much money you have left, then think motor etc.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Excellent! Check the TV bushing...
"Interior is plush....what should I do?" - Roll that beeaych!
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
Pete
