View Full Version : Password visible on screen?
King_V
03-14-2012, 11:57 AM
Ok, this seems a little odd.
If I go straight to grandmarq.net/vb and try to log in from that screen, the password shows up as text.
However, if I leave the username and password blank, and click Log In, login fails, but it brings up a different screen where I can enter my username and password, and password just shows up as a bunch of black circles, as one would expect.
What's happening?
slymer
03-14-2012, 01:39 PM
it's been like that since the "upgrade"
Those fields at the top of the page don't work. You have to use the next ones down on the main page or do what you're already doing.
gadget73
03-14-2012, 05:29 PM
Its the crappy theme. People seem to like it, though its not fully compatible with this version. There is an option to use a stock vb4 theme, though it isn't the default. Everything works properly on the stock theme. Selection box is way down at the bottom of the screen.
slymer
03-14-2012, 09:48 PM
I say go stock. I like it when shit works.
If people want a different theme after they login, they can change it in their user CP.
:2cents:
sxcpotatoes
03-15-2012, 10:27 AM
:2cents:
I know, why can't people just be content with a lopo 5-0 & 2.73 gears and the 2G alt!?
slymer
03-15-2012, 06:05 PM
sure, but to make the case similar, you have to make the passenger door lock the only one that works on the car and to pop the trunk requires the key in the ACC or ON positions and using the button since the trunk key lock is broken. Crawl through the car to open the driver door to get in since the lock actuators and key lock on the driver door are broken.
