Battery charging- MPG improvements
    Gentlemen,
    Need some input from some electrical smart guys out there. I have done some electrical work in the past (wind turbines, not cars). I was thinking about putting some solar panels on my dash and/or back deck and wiring them to the battery IOT reduce load on the alternator and alternator charging time. Less alternator charging= better mileage. Some guys on eco-modder are getting 3-5% better mileage by installing an alternator cut-out switch. I was thinking this might be good for a few percent improvement. Any thoughts?
    2004 Mercury Grand Marquis LS
    185 degree stat. 21mm rear swaybar with moog end links, Moog progressive rear springs.
    JLT intake, B&M transmission pan, 2.25 inch duals, magnaflows, Powerstop drilled/slotted front rotors and ceramic pads. Kenwood Excelon deck, Kenwood 6x8 3-ways all the way around.
    Harbor Freight buys their top quality tools from the same factories that supply our competitors. We cut out the middleman and pass the savings to you!
    Something like this....
      I was thinking diodes to the battery (to prevent backfeeding and fires), and a fuse on the solar panel end (in case the diodes fail). Maybe a bigger alternator pulley for the reduced load also.
        Can the system be kept at 12 to 13 volts. Lower than that will cause issues with the ECMs output.
          Should be 12 volts at 15 watts (1.5 amps)
            How much will this cost to install? I can't see getting your money back in even the first year or two? You said a 3-5% increase, which is less than 1MPG. You could probably pick that up by inflating the tires a little more which costs nothing.
            Past Panthers
              Solar panel about 60 bucks. Wire, don't know (I have it already). Diodes, don't know- not much. Fuse, not much. Battery terminal doo-hickeys maybe $10?Understood that it isn't much of an increase, but one way of looking at it is dropping the price you pay for gas by 20 cents a gallon at a 5% increase in efficiency. 15 gallons per fill-up = $3.00 saved per fill up, which translates to about $6 a week for this guy. 52 weeks in a year adds up to $312 a year. So for a hundred dollar (max) investment, I save $300 a year- sounds good to this guy. I understand tire pressure makes you more efficient. I run LRR tires and 36 psi. I don't look at it as one or the other. How about I do both? Trust me- I am not about losing money on something like this.
                Switching out the alternator is easy, just interrupt the green/red wire to shut it off. Problem is, with the electrical draw and the ECM it really needs good clean stable voltage or you risk doing more harm to the electrical system. That $300 a year savings will go out the door real quick if you smoke an ECM from power supply problems. I suspect you'd get better and safer gains from underbody aerodynamics. Add a splash pan from the front bumper back to the firewall to "clean" the airflow under the car. That would probably be less expensive, and I'd bet it would get you the same or better fuel mileage increases.
                  And theres the reduced battery life to deal with...
                  Alex.
                    Well the idea is not to cut off the alternator, but to charge the battery with some solar so the alternator does not have to charge as much....make sense?
                      Maybe pullies would be a better idea...hmmmm. I need some data on this stuff! (load when everything is on- average load, effect of alternator charger on MPG, etc)
                        I had a very different scenario where I had my electric fan mod kicking on, and of course, ALL current comes from the highest voltage source around, so the fan would full-field the alternator when it kicked on. My 1000+ cca battery didn't come into the equation.
                        If your solar cells contribute 12V and the alternator is contributing 14V, the cells... won't contribute at all. They won't come into play until they match or exceed alternator output voltage. So make sure you tack on a 3v cell in series to get a 15V solar cell.
                        Also, an alternator is "self regulating" in a manner of speaking. The amount of load it puts on the system, the amount of torque it takes to turn, is directly proportional to the current flowing through it. I think: correct me if I'm wrong, or, if the equations aren't so linear. A kill switch should be unecessary, and, seems like a dangerously overengineered weak point (as far as failing to come back online when you turn on the a/c and suddenly try to pull 20amps through your little solar cells).
                        I'd just add 15V of supply and wire it on in!
                        Make sure that it safely and successfully drops to the alternator voltage, because, obviously, it can't sustain the ouput.
                        Err, what I mean to say... with my fan example, the alternator couldn't keep up with the fan, at least not when it started up (after it was running, it could), so theoretically system voltage would drop and drop until it reached 12.5V or so, battery voltage, and the battery would start contributing.
                        So if you wired in 15V of solar cells, when it can't sustain the current draw of everything, it should be able to safely drop to 14.5V where the alternator can take up the rather significant slack. I think, there won't be problems here. But for a second, you might end up with blown fuses or fused wires to your 15V solar cell system when it tried to pass 30 amps of current for some sudden load, like the a/c clutch, electric fan, or giant sound system, etc.
                          Hmm... there are definitely charts of alternator potential current output vs rpm,
                          just for random example: http://www.pkys.com/Alternators/Curves.JPG
                          So putting a larger pulley will effectively make your alternator lower output; it'll turn at fewer rpms.
                          The only limit on the high rpm side of things is the bearings, I think. That is to say, why not just have a tiny generator with a tiny pulley spinning at 20,000rpm to make a 200amp alternator with very little copper? Because it would come apart at the bearings, or the wiring would overheat, I think is why.
                          As you see the curves are very steep at first, so just make sure that at a 700rpm idle your output with your particular alternator will be at least maybe 30amps, or you're going to have trouble with the air conditioning.
                            reducing the load on the system may be easier and more effective. Swap the incandescent bulbs for LED, stuff like that. Underdrive crank pulley may also help some since it would reduce the speed of all accessories, at the possible downside of reduced AC performance at idle or maybe reduced power steering assist
                              I believe you have a point gadget!
