View Full Version : Where can you get those U-shaped keys to remove factory Ford radios?
Where can you get the little U-shaped keys or whatever they're called for removing factory Ford radios from the dash?
Also, I think I've heard of people using bent coat hanger wire also -- anyone done this?
Thanks
marquisman
04-10-2012, 07:35 PM
you can get em at wallmart. or anywhere that sells car audio for that matter.
I had just called Car Toys and they said they didn't have them and had no idea where to get them. I figured if anyone had them, they would. But, I'll run up to Wally World and see if they have them. The problem with them is most of the time the sales associates are clueless -- if you can find one, that is.
jaywish
04-10-2012, 07:46 PM
You local parts store will likely have them. They are common.
Pesty351
04-10-2012, 07:54 PM
Anything metal that will fit in the holes will work. I usually use nails.
Thanks for all the info and help. I just ran up to Wally World. They had a set for $6.
By the way, how do you know if your radio is "code protected?" The instructions in the removal tools said that if your radio is "code protected" you will need a code to get the radio to work when you reinstall it after taking it out.
gadget73
04-10-2012, 09:57 PM
that'd be on the modern ones. If its in a box, its definitely not code protected. I dont know when they started doing that though, probably late 1990s.
One of the radios I'll be dealing with is in a '97 Aero Panther. Another is in a '00 Focus. They are both factory Ford radios.
miamibob
04-10-2012, 10:05 PM
What year car/make are we talking about?
miamibob
04-10-2012, 10:06 PM
Just saw the latest post - those are probably protected.
:wave: Hahaha! We posted the question and answer at exactly the same time.
By protected, you mean I will need some sort of code to make them work? Where do I get the code and how do I enter it?
miamibob
04-10-2012, 10:37 PM
I think that is a "dealer issue" - not sure if there is a "hack" around it.
jaywish
04-11-2012, 03:09 AM
The 97 panther should be no problem, no code. I do not know anything about The focus.
zoomie
04-11-2012, 05:57 AM
as far as i know the focus has no code, i had one, but i never did put the stock radio back in though i doubt it has a code.
miamibob
04-11-2012, 08:49 AM
Can always call the dealer. If you get an honest Service Manager you're all set!
1980c10
04-11-2012, 10:20 AM
I have an 03 focus and have had the radio in and out of it a ton and never had to put a code in.
Thanks for the help, guys. I appreciate it a lot. I got my $9 Ford 1.5 DIN Ford AM/FM bone yard radio installed in my '97 Aero, and it works great. I had to put another on/off/volume switch in it though because the original one wouldn't stay pushed in, so the radio was always "on." I found the same type of switch in another bone yard radio and swapped them.
I need to take my Focus radio out so I can see if I can fix the clock set button that somehow got pushed into the radio.
Thanks again for your help.
