Is the air suspension ride height on late aero's adjustable? Also, is there a way to determine what the proper ride height is? Thanks.
Is Air Suspension Ride Height Adjustable?
It is adjustable. If I remember correctly there is a lever just above the center of the rear end where the height is set. Ride height may be specified in the manual. You can set the car so it is lever or just slightly raised in the rear. Just measure down from the front of the pinch weld and from the back of the pinch weld. It will change the alignment. Make sure you like the setting and go for a full alignment afterwards.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
What he said. The height sensor mounts to a bracket on the body and has a lever with a ball end on it. There is what amounts to a tie rod from there to another ball mounted on the driver's side upper control arm. The control arm ball usually has 3 spots it can be set for coarse adjustment, and then the tie rod is threaded for fine adjustment.86 Lincoln Town Car (Galactica).
usually level or very slightly tail-up is where it wants to be. Thats what the factory does at any rate.86 Lincoln Town Car (Galactica).
This is the aero forum, not the box forum. On my drivers side upper arm on the rear end, there are 2 nuts that hold the sensor on. Loosen them and slide the sensor one way or the other to set your height. IMO, there's no need for a rake with air ride because the ass will never sag with a load in the first place. Sounds like the box air ride setup differs slightly, unless they changed it up again with the whales.1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
Originally posted by Crownvicman289 View PostThis is the aero forum, not the box forum. On my drivers side upper arm on the rear end, there are 2 nuts that hold the sensor on. Loosen them and slide the sensor one way or the other to set your height. IMO, there's no need for a rake with air ride because the ass will never sag with a load in the first place. Sounds like the box air ride setup differs slightly, unless they changed it up again with the whales.
In regard to boxes, I didn't know they had air ride. I've got an '89 that has factory air shocks w/ pump, but the main springs are steel coil.
Correct, The old ones are air shocks the "new" ones are air springs. Both are adjustable.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
It is adjustable....to a point. I was a L-M service advisor 95-97 and Handling Package cars had different settings on the air ride than "standard" cars. As an example, we had a customer that ordered his wife a 95 Cartier Town Car with the handling package because he thought her 93 was too "soft". What he didn't know (or sales didn't tell him) was that the 95 TCs got an upgrade to the suspension along with the new interior and thin headlights. She HATED it! Said it never rode like a TC should; it was too harsh and looked like a "hot rod" jacked up in the back. We played with it a bunch, even "shade tree"ing some things and finally got it to where she would tolerate it. I got to drive it quite a few times as they lived near me and I would pick it up and take it to work when it needed service. I thought it was great....drove like a CVPI with all the Lincoln goodies on it!____________________________Captain Slow____________________________________
"One useless man is a disgrace, two become a law firm and three, or more, become a congress"
2006 Grand Marquis LS: Silver Birchwood w/Black interior, Sunroof, "Y"spoke wheels. No performance mods.
Convienience "mods": Driver's center armrest from 97 Town Car for storage, FM Modulator on stock sound system, Garmin Nuvi 1350,
Cobra Radar/Laser detector, Midland 75-822 CB/WX radio.
Originally posted by TSgtRet View Post95 Cartier Town Car with the handling package because he thought her 93 was too "soft".2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Originally posted by TSgtRet View PostIt is adjustable....to a point. I was a L-M service advisor 95-97 and Handling Package cars had different settings on the air ride than "standard" cars. As an example, we had a customer that ordered his wife a 95 Cartier Town Car with the handling package because he thought her 93 was too "soft". What he didn't know (or sales didn't tell him) was that the 95 TCs got an upgrade to the suspension along with the new interior and thin headlights. She HATED it! Said it never rode like a TC should; it was too harsh and looked like a "hot rod" jacked up in the back. We played with it a bunch, even "shade tree"ing some things and finally got it to where she would tolerate it. I got to drive it quite a few times as they lived near me and I would pick it up and take it to work when it needed service. I thought it was great....drove like a CVPI with all the Lincoln goodies on it!
