the cp is shifting early i noticed that sense this is an 86 it doesnt have the bushing like others do. it has a plastic piece like chevys use that slides onto the tb instead of it being pushed or cliped in. is the adjustment procedure the same as the others or is this different. its shifting into od at about 35
86 cp tv adjustment?
1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
1986 mercury grand marquis colony park 5.0 sefi dual exhuast thrush turbos with h pipe and turbinesTags: None
The adjustment is at the bracket where the cable goes through. There is a small white tab on the cable that you flip up, and then you can adjust the cable.86 Lincoln Town Car (Galactica).
my shift points now are
1-2 17mph
2-3 27mph
3-4 37mph or 40mph. is this okay. she does have a k code 3.55 gear. what you guys think?1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
Sounds OK to me. If the motor isn't lugging going into overdrive, I'd let it be.86 Lincoln Town Car (Galactica).
Originally posted by way2old View PostAfter the lock is released, open the throttle completely and then lock the tab back while holding it in the wide open position.1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
give it some more then. Making it full at WOT is usually safe enough. Can't get it higher than that, and more pressure is generally safer than less pressure.86 Lincoln Town Car (Galactica).
