96 Sonoma 2wd
    96 Sonoma 2wd
    Well i needed a cheap daily driver that was good on gas after i sold the dodge back in february and ended up picking up this 96 sonoma 2wd. Its only a 2.2 L4 automatic with 124k on it. Vinyl flooring with a shitty bench seat and a rot hole under the sil plate on the drivers side i need to repair before winter. Funny thing is it goes the length and width of the sil plate and stops. I added the same model pioneer cd player i had in the dodge that i sold with it. Runs great and gets good mileage all that matters till i can get the mercury fixed.
    Repairs done
    New rotors, pads with bearings, races and seals
    All 4 shocks replaced with Gabriel Pro Guards
    Gabe wired up the fog lights for me
    New idler arm
    New center drag link
    Replaced a tailgate cable
    Installed a sunpro oil gauge with copper line
    New cheapy coil packs
    replaced the rusted away head light buckets
    both upper ball joints since the passenger busted on me while driving home one night
    replaced the gas lines
    rebuilt the motor and added a stainless header
    thermostat
    muffler and tail pipe
    pcv valve
    swaybar links
    all new motor internals when i rebuilt the motor except cam and cam bearings (because the motor shop told me they were fine but i still have shitty oil pressue at idle from the bearings)
    I just picked up a nice set of rims from an extreme for it today.
    First pic is the day i got it, i did remove the tail light covers since i didnt like them. 2nd Pic is with the new rims i just got.
Name:	Day i got truck.jpg
ID:	1299074Click image for larger version
    2018 F150 XLT 43k
    1970 Buick GS 455 Stage 1 44k
    1968 Buick Riviera
    make sure the trans cooler lines recall has been done on it. They used O rings on the trans instead of something that will actually seal at high temps and they leak. The recall addresses this and changes the fittings.
      The trans lines and all 4 brake lines were brand new when i got it.
      2018 F150 XLT 43k
      1968 Buick Riviera
        hopefully the fittings are compression/flare/etc and no the original o-ring style. It was a 1-year screw-up. My cousin had a 96 S-10 (all S-10/Sonoma/Jimmy/Blazer used the same thing) and had to deal with that. Just a heads up in case you start seeing something leaking from the trans.
          My brother was out riding around the area last night and found me this in the garbage. Its cracked but im going to eventually switch over to this style now that i have the assemblys.
          2018 F150 XLT 43k
          1968 Buick Riviera
            I never update this but i changed from the bench seat to a 60/40 split and put a floor shifter in its a B&M racheting megashifter. The pic shows what it looks like. Ill take an interior shot one of these days. Click image for larger version
            2018 F150 XLT 43k
            1968 Buick Riviera
              Nothing wrong with that a nice 4.3 or 350 wouldn't fix. Stupidly its actually less expensive to stuff a V8 in one of these than fool with the 4.3. I considered headers on mine years ago but changed my mind when I saw the prices. Kind of a shame, the 4.3 hauls ass in a serious way in an S10.
                I have a header on the 2.2 along with a cheapy cold air intake i got off ebay, they make the truck a bit faster.
                2018 F150 XLT 43k
                1968 Buick Riviera
                  just doesnt seem those 2.2's hold up that well in the trucks. I've known a lot of people that had them die in significant ways. I guess thats what happens when you put a Cavalier motor in a pickup truck and try and work it like a fullsize.
                    yea the 98 runs better then the 96. Dont know why this one just doesnt run like it should. Head gasket is leaking into the back cylinder but its still going. Thats the main reason for buying the 98. Just waiting on the kid to find the title or do lost title replacement before i go and finish paying him for the 98 and then it can swap places with this one.
                    2018 F150 XLT 43k
                    1968 Buick Riviera
                      So this rust in the floor or what was the floor needs to be taken care of ASAP. I need to find a floor pan soon as possible or shortly after i get the other truck on the road. Head is bogging the engine down worse and im starting to think the V8 swap is going to be a good idea. Keep in mind that isnt the only hole in the floor. The sill on the driver side hides the practically length long hole near the outer part of the floor.
                      2018 F150 XLT 43k
                      1968 Buick Riviera
                        So today its starting to run like shit. Hope the title for the other one is in fast. I cant keep driving it like this or its gonna go and i dont need a tow bill i cant pay. Got to a gas station earlier and went to leave, it took 5 minutes of cranking it to get it to start. Usually its flick the key slightly and its on. Could smell the coolant on the drive home.
                        2018 F150 XLT 43k
                        1968 Buick Riviera
                          Well the title came in for the other truck so i swapped over to it. It will be on the road today and this one will either find itself a new motor in the future or a new owner.
                          2018 F150 XLT 43k
                          1968 Buick Riviera
                            Truck is going either to the junk yard soon or someone else. I was suppose to trade for a 94 v6 camaro earlier and came home got the truck running tried to get it prepped for the trip to the guys house to trade and it either blew the starter or the motor went when we tried to start it again. Was idling at 0 psi for oil when we shut it off, tried to start it again and there was a loud pop or bang and spark and nothing. Wont crank but its free and not froze. Not putting a starter in it. I rebuilt the motor once not gonna happen again. Cant afford a v6 swap dont even want to try anymore.
                            2018 F150 XLT 43k
                            1968 Buick Riviera
                              Its running again. Trade for camaro is still gonna happen if it makes it up otherwise its done for.
                              2018 F150 XLT 43k
                              1968 Buick Riviera
