tryin to figure out what spline rear end i got in my signature series so i know what to order when i order my trac-lok
'01 TC Rear End
'01 TC Rear End
2010 Toyota Camry "Traveller II "
54,xxx miles. New daily driver
2001 Lincoln Town Car Signature "Leroy"
rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
114k miles. Sold to my coworker.
1998 Toyota Camry "Traveller"
Dead and sold. -
I've got it listed as 28 spline.
thanks! would this change if i changed to a 3.73 or 4.10 ratio?2010 Toyota Camry "Traveller II "
Dead and sold.
you would have to change the axle shafts and pinion flange to change that.
So you'll also want the 28 spline setup for the gears (they make them all the way up to 4.56 I think).
The 8.8" pinion and ring gears are all the same regardless of the drive ratio you choose and work with any axle.
I believe the spyder gears and the carrier are different for different axle spline counts, though I am not 100% sure about that part. It may be just one component.
Sly, you say you need a different pinion flange if you want to change the axle spline count?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
the pinion gear has a spine on it... so you have to match that up with the pinion flange (drive shaft setup) as well.
the spider gears have the splines... the carrier is actually universal.
Interesting. What types of vehicles have a different, (not 30) pinion flange count? Trucks, PI?
I did scan summit's listing and found a yukon set with a 28 spline count but can not tell what it fits.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
actually I can't find a definitive answer. It seems 28 or 30 for ALL Ford 8.8 rear differentials. It may have something to do with tow options. Maybe the tow and HPP packages got the 30 spline.
This one will have to be deferred to a higher authority on the subject.
Oddly it seems that the 30 spline pinions are the common ones and 28 the uncommon. For instance it appears that all Ford racing pinions are 30 count. Almost all offerings at sumitt are 30.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
this is true... and I know for a fact that the axle splines are 28 and yet only ADTR has the FRPP 28 spline traklok carrier (that I've found recently). So I dunno.
Did town cars come with aluminum driveshafts? If not he's going to want to fix that if he goes to 4.10s and ever goes over 80mph or so.
Originally posted by slymer View Postthis is true... and I know for a fact that the axle splines are 28 and yet only ADTR has the FRPP 28 spline traklok carrier (that I've found recently). So I dunno.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I talked to ford racing support. They tell me that all 8.8 ford rears are 30 spline from the factory no matter what vehicle the rear is in and have been since 1984. I also talked to summit and they gave me the same information. This means any 8.8 ring and pinion will interchange in any 8.8 rear.
I do see some 28 spline pinions available for sale but perhaps they are all custom aftermarket setups. I am glad this was brought up as I think I am a bit more clear on this now.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
That's good info. So it's just the axle splines to deal with.
Yes axle splines and the related spyders.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
