Desirable '90 TC parts
    I know the Lincoln-log headers are cool, but wasn't there some other stuff like the radiator overflow/separate wiper fluid reservoir that mounts right in our boxes & lets us use newer airboxes and such?
    I'm just too lazy to go hunting for the answer in the threads here. Thanks.
    Yes the shroud and coolant bottle, I think the drivers inner fender with the relay/air tank is also a good item.
    Past Panthers
      90TC fan shroud with coolant bottle... then use aero washer tank... then use MZT for intake hose/filter and even MAF setup if doing MAF HO conversion.
      +1 on inner fender and vacuum reservoir/relays.
        the 1 year only steel bumpers
          Pantera77, are those steel bumpers interchangable with ours or are they specific for the aero towncars?
            They would be specific to the aero Town Car, and probably only '90-'94 at that as the header panel, grille and lights all changed in '95 and I doubt they would fit right with the older bumper.
            -Steve
              On that inner fender vacuum relays etc, is that both or only D or P side? Just called the place, and they want $25 for the shroud/bottle if I pull or $50 if they pull, so it's easier just to do it myself. Pretty simple to get off, right?
                Yeah...but the plastic studs some times break off. It is located on the drivers side by the brake booster if it is the same as the vics and marqs
                  the shroud is as easy as any other mechanical fan bugger. Once you get the fan loose... top two bolts and lift out.
