fuel gauge not working
    i pulled the fuel tank a couple weeks back to replace a leaky fuel pump seal and when i reinstalled the tank, my fuel gauge went to 1/2 and won't move at all. i pulled it back out and made sure the float wasnt stuck and installed it again. still at 1/2. now im using the trip meter (or whatever the hell you call it) to figure out how much fuel i have. i think one of the wires might have gotten split somewhere when i installed it but i cant figure out where...any ideas?
    2010 Toyota Camry "Traveller II "
    54,xxx miles. New daily driver
    2001 Lincoln Town Car Signature "Leroy"
    rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
    114k miles. Sold to my coworker.
    1998 Toyota Camry "Traveller"
    Dead and sold.
    Check the connector that plugs into the tank. Make sure it's installed correctly, and make sure none of the wires are loose going into the connector as well.
    I don't think that there is a fuse for fuel indication.
    You can pull out the float and have someone watch the gauge as you slowly move it. Hopefully it should read correctly.
    I'd also unplug the connector to the tank and turn the car to ON (Don't start it. Because is won't.) It should zero out the gauge and not read anything because it's not getting any signal. Then it would be a bad fuel sending unit.
    I hope this helps.
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      thanks ryan! i'll probably give that a try this weekend or next week
      Dead and sold.
        I had the snaps break off on mine and it wiggled itself free after I crossed some railroad tracks. Then the car sputtered and bucked a bit, then died.
        I sealed it in with a aircraft-grade 2 part epoxy, so, it's safe to say it's never disconnecting again.
        Let us know how you make out!
          well thank god that it aint done that to me! haha! id be pretty pissed if that happened. ill be in touch
          Dead and sold.
