Looking at a 94 GM, have some questions....
    I hope this is the right place for this.
    I'm considering buying a 94 GM with 184xxx Km's (not miles). Its an older retired guy with it that bought it from the original owner or that's the story at least.
    The car is clean, never smoked in, seems to run really well, although valve seals could be hard to diagnose in the cold. But it has a few little things that i'm wondering if its common to lead to more serious issues.
    First one which is relatively minor is the right rear window drops a little and needs assistance going up. I'm pretty sure its the guts in the window motor since it seems to be the same as my T-bird was.
    The ones that bug me a bit are the heater control and fan. Its not climate control, the sliders to set floor, defrost, etc have to be wiggled around a lot to hit the right spot for the heater to even come on. Then the fan only has hi, all other speeds are dead. I'm assuming that's the resistor coils that are burnt. My truck was bad for those.
    Also the clock is not working at all. Again minor but being right in the same area of the dash should I be worried about wiring issues and possibly shorts that could get a lot worse?
    Also where is the fan resistor on these cars?
    Other thing is it did have the trailer package but the hitch is removed now. He says it only pulled a small trailer but didn't say what type or how heavy. Should I be concerned with the trans having issues?
    If the car had a towing package from the factory,i believe that means it has a trans cooler. If so, then I dont think towing a little trailer would have done any harm to the trans. Just my 2 cents
    And these cars are notorious for having window motor problems, they arent too hard to fix. I think the biggest pain is getting the door panels off and back on.
    -85 Town Car: Crushed, gone to a better place.
    -91 Grand Marquis: With the Town Car
    -94 Grand Marquis: My DD
      I've done all four motors in my Tank.
      My clock was acting funny, so I just replaced it with another one from the yard and problem solved! (Every time I would hit the fuel door release, the clock would reset to 12:00)
      08 Lincoln Navigator L - 233k
      03 Mercury Marauder- 63k
        Any ideas on the heater issues?
        Its cold out right now and intermittent or no heat would suck.
          the controls are notorious for the vent control being like that. as for the blower resistor... only if you have manual controls... it should be in the same place as the boxes (just to the right of the heater core under the hood). If it's the automatic controls... it's under the dash in some unknown to me off the top of my head location. I'll try to remember to look it up during lunch today.
            Just checked... either way, it's in the same spot, just different connectors and the ATC version is a pricy bastage. typically can be fixed by refreshing the solder joints.
              Cool thank you.
                If 94's had the plastic intake, its surely been replaced by now, but that is one thing to look out for on 4.6 cars.
                Also if the ball joints are original they are most likely bad. I'd get those checked by a shop, if you know how the owner still might not want you "messing around with it" if he's crotchety. Also I'd look for wetness from rear axle seals on the backing plates. All you have to do is peek from underneath to see that. Also check if the parking brake works, it probably doesn't.
                  nah... 94s have the aluminum intake of suckage just like all other 92-95 aeros.
                    What's the asking price?
                    '79 Continental Town Car
                    '90 Crown Victoria LTD
                    '94 Crown Victoria
                      $1500 but he is somewhat open to offers. And he kind of wants my 94 Sonoma.
                        Atleast its not the plastic intake of breakage!!!
